Results 1 to 7 of 7
    Feb 2011
    colorado mountians
    Climatrol air handler 43years old looking for parts
    Hi all hope someone out there can help. I have a climatrol air handler (cold deck,hot deck) mod. CM-32.00 ser. 13A69N-2.03 that has a two piece blower shaft with a rubber coupling between the two shafts/ wheels. The rubber is obviously worn out, but trying to find anything on this unit is leading to dead ends. Any suggestions other than 5 gal gas and a railroad flare?
    South Texas
    Sounds as tho there is a Lovejoy coupling. Get shaft size and you should be able to find a replacement. The tough part is getting the old one to move, sanding and lots of wd 40. May have to pull one of the shafts
    Feb 2011
    colorado mountians
    Not a love joy as we know from pumps now adays but more like a giant version found on glycol transfere pump. kind of a cross looking deal
    Oct 2008
    Quote Originally Posted by MUNC View Post
    Can you convert to a lovejoy? If not, maybe a picture of what you got can help someone here identify what you need.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
    Visit a power transmission vendor where you can get bearings, couplings, sheaves, belts, etc. This ain't rocket science so with a shaft size and a distance between them dimension, you should be able to find one flexible enough to fit your application. Here's some examples:http://www.mcmaster.com/#standard-sh...plings/=lw0p74.
    Good Luck!
    Southern NJ
    I know the type of couling you are referring to. You may want to use a heavy-duty coupling such as a Dodge Paraflex.
    Apr 2005
    Boulder,CO.
    Try Whisler in Denver, www.whislerbearing.com/
