Results 1 to 9 of 9
01-18-2007, 09:43 AM #1
- Jan 2007
- 4
Emergency Heat & Electronic Thermostat
I want to switch to an electronic thermostat but was told that would be hard (expensive) because I have an emergency heat switch on my current system. Is it possible to switch to the electronic thermostat and what brand/features should I look for? (I am NOT hvac savy -
01-18-2007, 09:58 AM #2
many digital thermostats have emergency heat setting built into them
what kind of system do you have?
my personal preference for digital stats are the Honeywell vision pro line
01-18-2007, 10:06 AM #3
- Jan 2007
- 4
I have whatever came with the house
-I believe it's honeywell...<---that sounds about right...I can go to Home Depot/Lowe's and pick up a system and install myself or will I need to an expert install it?
maybe I should take a picture of the system before I go?
01-18-2007, 10:23 AM #4
not the thermostat the system ie electric heat with heat pump or gas furnace with a/c forced air or water
and i dont think you should hook this up yourself and you can get a better thermostat from a hvac company then you can from home depot
01-18-2007, 10:40 AM #5
You can also fry the low voltage wiring on your entire system if you make a mistake doing this yourself. This is a difficult install. Call a pro and let him bring your thermostat, dont go to HD and get the wrong one. Tell um on the phone you've seen a Honeywell Vision Pro and want that........
Walter Matthau
01-18-2007, 10:42 AM #6
- Jan 2007
- 4
now if we were talking about statistics I wouldn't be lost -LOL
the entire house is electric...
thank you for the input...I will contact a local HVAC company for assistance...also is there a listing (besides the yellow pages) that rates the services of local HVAC companies?
01-18-2007, 10:44 AM #7
- Jan 2007
- 4
01-18-2007, 10:47 AM #8
Any thermostat that is specifically designed for HP has EM.
You might be able to install it your self, but I would not suggest it.
There are always lots of options that must set and addressed. Just not a DIY job.
01-18-2007, 10:41 PM #9
Unless you have superior electrical knowedge -it would be less hassle and less expensive to hire a local company to install one for you.
If you miss wire it you may cause more damage to your system
Finad a good local con=mpany you can trust to install it for you - ask them to leave the installers instructions as well as the user instructions whe nthey are donewww.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
Gonads serve a useful purpose but are no substitute for brains
