Vacuum rated valve core remover tool
Does anybody know a brand name / pn for a vacuum rated core removal tool? I currently use a yellow jacket and have never had one that didn't leak.
Appion
MGAVCT 1/4" MegaFlow Vacuum-Rated Valve Core Removal Tool Black
MGAVCR 5/16" MegaFlow Vacuum-Rated Valve Core Removal Tool R410a Rose
It's not what you're capable of doing that defines you, it's what you do on a daily basis.
 Originally Posted by billg
Appion
I think it's worth mentioning (since the OP asked) that Appion is the only one that has a traceable NIST rating down to 20 microns and the C&D brand are factory rated (no official test cert rating) to 200 microns.
I don't know about YJs core tools rating, although the C&D factory said they made some core tools for them and JB.
Thanks. Just what I needed.
Only thing about the appion crt I don't care for is the rubber wears down fast. I only fiber tighten it and been through 2 o ring repair kits already. Don't use it frequently enough to think it's a normal wear and tear thing.
Sent from my SGH-T999 using Tapatalk 2
Another vote for appion.
Still waiting for o ring seals to get chewed up or fail.
So far so good. However you do get what you pay for $40+ .
I also have a C&D plus a YJ. They're okay but definitely not as weighty or well made as the 2 Appions I have.
Where are you finding Appion CRT for $40 +?
Best I have seen is low fifty dollar range.
Appion
Exactly
My yj leaks also. I'm getting a set of appions
Appion.
Sent from my PG86100 using Tapatalk 2
Appion had a few problems with the extractor but responded and the new tools are great. Never heard of the 'O' ring problem with them.
There is a guy on H-talk that sells an extractor for broken Schrader cores-
http://www.valvecoretool.com/
Keep the fire inside the fireplace.
- You may not post replies
- You may not edit your posts
Forum Rules
