Results 1 to 4 of 4
    Nov 2010
    Taylor C602 shake not filling
    I am working on a Taylor C-602 unit and have a problem where the cup is only filling 1/2 full on the shake side, fills for about 2-3 seconds, well below sensor level. I have already replaced the pyro sensor, pyro sensor board and personality board. I am currently ordering the shake side interface board. This machine is only about six months old. The shake temp is 23F in the cup. I have readings of 2.5 vdc at the pyro sensor and drops momentarily to 2.0 vdc when the shake fills to sensor level. Actually, the original problem was the cup would overfill but now it underfills after replacing these parts. Any help would be appreciated.
    Mar 2001
    Quote Originally Posted by western View Post
    Did you try adjusting the sensor height?
    Apr 2016
    soft taylor
    Hi, I'm refrigeration engineer in Argentina, I would like to know whether to detect problems with the new soft machine taylor need a software, if I plug the machine to a computer and from there to detect some problems, or everything is handled from the machine, thank you very much
    Jul 2012
    Everett, WA
    No computer is used, I work for DSL NW which is Taylor certified for Pacific Northwest
