Results 1 to 13 of 16
    Aug 2012
    Portland, Or
    R-22 replacement advice/help
    Gentleman,
    Any advice on which refrigerant to use for replacing R-22. Im seeing a lot of them out there, and thought I'd jump on here and find out which is best for low, mecimum, and high temp systems?
    Feb 2013
    NE philly
    hot shot
    Southold, NY
    Quote Originally Posted by Legitshop View Post
    hot shot
    Not for 22
    Feb 2013
    I've had no problems dropping in MO99 in most systems.
    Aug 2012
    Portland, Or
    Hot shot post is just a up being an ass
    Oct 2007
    Broward County, FL.
    We have been using R422D for high temp.
    I miss you mom and dad.
    Atlanta GA area
    R407C is approved by a few dry unit makers for AC
    Aftermarket probably MO99 (cheaper).
    Note there are NO, repeat NO 'drop in' substitutes one can mix with R-22. ALL must be replacements, and most will kinda behave with MO... yet better with POE.
    GA-HVAC-Tech
    French Settlement, Louisiana, United States
    Which replacement has the best capacity match to r22 with no oil change?
    Atlanta GA area
    Quote Originally Posted by coolcajun View Post
    Probably MO99... It has an additive to make it work better with MO.
    Talk to a few folks before you make a decision.
    ALL refrigerant changes require: remove (recover) old juice, flush (N2 or chemical), change oil if necessary, ALWAYS change LL filter/dryer, install new refrigerant.
    GA-HVAC-Tech
    [QUOTE=ga-hvac-tech;15363431]Probably MO99... It has an additive to make it work better with MO.
    I was aware of that. Also was told have to replace shraders with M099.
    Atlanta GA area
    [QUOTE=coolcajun;15363951]
    Quote Originally Posted by ga-hvac-tech View Post
    Yes, I did not post that... replace schraders with any oil change. THX
    GA-HVAC-Tech
    Does anything besides MO99 have specific SNAP approval as a retrofit replacement for R-22 yet?
    Atlanta GA area
    Hmmm... have not heard of SNAP approval yet... could you post a link?
    GA-HVAC-Tech
