Results 1 to 13 of 18
    Feb 2013
    Heat Pump will not throw heat
    Since the beginning of December when a honeywell VisionPRO TH8000 series was put in, the heat pump has not been throwing heat. The guy doing the work has changed the contactor, defrost control board, and refrigerant and when on the phone with honeywell to try to troubleshoot the problem, they said it was the compressor. Rather than go through the issue of replacing this and possibly not work, he put in a Ducane heat pump, initially had a Bryant. The heat pump still will not throw heat. We are running our Emergency heat which is propane. He has no idea as to what it may be, and plans on trying a different thermostat to see if the problem is with that, and contacting honeywell again. All fuses have been checked and are fine. Just looking for a little bit of advice on what may be wrong, and would be greatly appreciated.
    Nov 2009
    Central Virginia
    My advice would be to call someone else. Just sayin.
    Sent from my SPH-D710 using Tapatalk 2
    ____________________________________________
    If you don't know what you are doing.... ASK!! There is no such thing as a "Stupid" question.... Maybe.
    Jul 2010
    nebraska
    Sounds like you need another guy. It's not that hard to use a meter and find out which component isn't working.
    Contactor, defrost board AND refrigerant. And the new HP doesn't work.
    Your technician is doing you no favor.
    Wow. You need someone that knows what the doing. If the problem only started after the new thermostat was hooked up. then its a problem with the ay its wired or how it was set up.
    Nov 2009
    Central Virginia
    I mean all the things listed that he has done is absurd. Im sorry you have spent all that money and wasted so much time. But I mean come on. It should not be that difficult to diagnose this. Good luck.
    bullmoose
    Please check your PMs.
    Thanks,
    AOPC
    as they have all said already, you have the WRONG person there, I will not use the word technician for him!!
    Call someone who knows what they are doing before you hand over more money for nothing.
    Dec 2011
    Fort Worth, TX
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    Jbart, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Virginia
    time to replace the technician
    Go Trump
    Mar 2011
    Canada
    sounds like a thermostat programming issue to me. u need a new tech to fix u up.
    May 2012
    north carolina
