Results 1 to 10 of 10
    Feb 2013
    Purchassing a Trane XR15- Concerned about Fan noise level
    Hello,
    I am purchassing a Trane XR15 (Single stage) 15 seer unit next week and am concerned about fan noise. My neighbor has an older XR13 (2006) and although the compressor is quiet, it has a conventional fan blade and a slotted grill with half inch slanted slotts all the way around the top rather than a normal wire mesh grill and it is very loud!!
    The XR15 condensor unit will be direclty behind my bedroom and my bedroom is upstairs with 2 windows directly above the condensor. I'm wondering if anyone has experience with the XR15 fan or noise level. I have heard the XR15 is using a different fan blade but appreciate any info you can provide.
    Thanks!
    Virginia
    the xr15 is quiet although the xl15 is quieter
    Go Trump
    DC Metro Area (MD)
    Quote Originally Posted by catmanacman View Post
    Agreed. All new XR units have a swept wing fan blade and wire mesh fan grilles. Noise shouldn't be an issue with an XR15 (75 db). Some sizes have compressor sound blankets.
    If you want a very quiet unit, step up to the XL15i.
    May 2009
    Cumming, GA
    The XR15 has a swept wing fan blade that will help keep the noise down.
    The average XR15 sound level is approx. 70-73 decibels. Example, 70 decibels is about the level of noise inside an average car.
    SW FL
    Quote Originally Posted by Brent Ridley View Post
    _ _ WITHOUT A PASSENGER next to you Or a back_seat_driver.
    What's a 3 db change?
    ________ ACTUALLY A LOT.!
    http://www.articlesbase.com/science-...ed-252817.html
    Designer Dan
    DC Metro Area (MD)
    Won't get as low as 70-73 dB on the XR15, but you could with the XL15i. See attachment below for comparison of heat pumps/sound levels.
    Trane_HP_2013.pdf
    May 2009
    Cumming, GA
    Those ratings are for tests under the AHRI standard 270-2008.
    You're unit wont be in a lab therefore it won't be exactly as listed.
    I've measured 70-73 decibels on an XR15 personally.
    DC Metro Area (MD)
    Thanks for clarifying. Helps to hear another perspective. I guess you can't take the sound ratings too literally, rather more of a reference.
    Feb 2013
    That makes me feel a lot better....Thanks so much everyone!!
