Results 1 to 13 of 23
    Noisy York Furnace sounds like New York
    I had my old gas furnance replaced today, which was about 21 years old, and due for replacement. It was replaced with a York Affinity single stage gas furnace, model #PV9B12N080UP11, 92% efficiency.
    This unit is LOUD, much more so compared to my old 80% unit. When the unit turns on, I hear a loud "wooshing" through my vents. The advertising for this unit says its supposed to be "quiet".
    Can anyone offer any thoughts as to why this may be so loud?
    Many thanks in advance...
    Ebachenh
    Aug 2005
    Pa.
    Have the company who installed your furnace come back out to make sure it is set up correctly.
    If the duct system was correctly sized for the old furnace, and the new furnace is the same or greater heating capacity, you likely need some changes to your duct system.
    Modern furnaces move more air for the same heating capacity than older furnaces, as much as 50% more airflow for the same heating output.
    feel your pain
    just wonder if your furnace is still loud. I just had a york affinity 8.s installed. now my house is like a factory. Installer came in 8 times, couldn't fix it. York technician claimed everything works fine. If that is the case, they need to re-evaluate the product design. Or they should warn their customer about this. So annoyed.
    Jun 2001
    Louisville, KY
    Undersized duct.
    Don't blame the furnace. It's only noisy because of the duct to which it is connected.
    So is it the installer's job to inspect the ductwork?
    Houston,Tx.
    Quote Originally Posted by I_want__quiet View Post
    No, my guess would be it was the person that sold you the job.
    Jun 2001
    Louisville, KY
    I have that discussion with salesmen quite frequently. They always tell me that they don't have time. I say BS. You can let the folks look at your equipment brochures while you drill a couple of holes and measure ESP. It takes less than 15 minutes to evaluate the duct system.
    You're selling comfort systems...not boxes!
    thank you
    Quote Originally Posted by jrbenny View Post
    Hard to get salesmen to check the static.We have found that if they don't, they get to share the cost to make the duct changes,works real well.
    Philadelphia, PA
    PV9B12N080UP11 - isn't this a two stage variable speed furnace?
    http://www.yorkupg.com/PDFFiles/036-...001-B-1004.pdf
    Is the thermostat setup for two stage heating? What type of stat do you have?
    The heating and the cooling airflows are preset at the factory. The heating airflow is set to the maximum CFM. Did your installer make any adjustments?
    What did your installer say when you complained about the noise?
    The PV9 is a 2 stage VS furnace.
    As others have posted. Sounds like the installer put in the same size furnace. And gave no consideration to the duct system, or if that was the right size furnace.
    The 80,000btu 3 ton drive model can have the blower slowed down 1100 CFM, and still have room for the air filter to load up.
    As a test. Have your contract slow the blower. And if he has second stage running off the timer, have him set it to 20 minutes.
    See if its quieter then.
    Feb 2007
    Unless both of them were idiots (which I highly doubt), they both knew that your problem was the duct work and air flow.
