Results 1 to 13 of 26
    Feb 2013
    New System or Repair Old?
    I think I am putting this in the right section, forgive me if I am not. I have a question, and hope someone here can give me some advice.
    I have a residental unit outside...2009 Goodman(Arcoaire) 3.5ton runs on R-22. The inside unit (air handler) needs to be replaced since the pan is leaking, and the system has leaks, as it is the original one from the house being built(date stamped 1988)
    Here is my decision...do I replace the whole unit, inside and out with a system which runs on the new coolant, or do I just replace the air handler. I already have qutoes to do both, and the different is about $, but I don't want to be cheap now and it cost me down the road. I hate to replace the outside system, as it is not even 4 years old and working great. But the concerns with R-22 being phased out and getting more expensive worry me.
    So, what is the RIGHT, while also being cost efficient, way to handle this? Is the R-22 thing being overblown and I should stay with my old system with a new air handler, or do I replace everything now.
    Also, I was told if I do replace the WHOLE system, I could capture the R-22 in the old outside unit and then be able to possibly resell that unit to someone who can't afford a new one? Is that legal? Possible?
    Thanks so much in advance!
    Goodman and Arco are 2 difference companies.
    Pretty hard to justify replacing a 4 year old outdoor unit. You could just get a new indoor unit for lots less than replacing all. You know your budget.
    As for trying to resell the old R22, forget it! Too much work and who knows how clean it is.
    Feb 2013
    Sorry, it's an Arco, I'm considering Goodman if I replace the whole system.
    I originally just wanted to do the inside fix, but had 1 AC guy tell me he wouldn't even do it, and with the government in his words "stopping people from using R-22 in the near future" it would be terribly stupid to not replace the whole system.
    I guess I'm trying to guage what the impact of sticking with an R-22 system really is. I know it is going up in price, but unless my system is leaking coolant, then should I really be worried about that?
    Like I said, I save upwards of $ just doing the inside unit, so at first I was leaning to biting the bullet and doing the whole system, but if there is nothing categorically wrong with leaving the outside unit, then it's something I would consider.
    Northeast Ohio
    To be honest, you should be saving more than what you are stating (pricing is not allowed here by the way, even generalized pricing). You are correct in the assumption that as long as the system is tight, refrigerant prices really are not a factor, none out, none in. Being a 2009 unit, it will be at least 13 SEER and easy to match to a new coil/air handler unit. While R-22 is rising in price due to pressure from the powers that be, there are already several drop in replacement on the market and more in the works. These refrigerant options are cheaper than R-22. As far as capturing the charge in your present unit and selling it to someone in need, yes it's possible but technically illegal depending on how you interpret the laws. Bottom line if it were me, I would probably replace just the idoor section.
    DEM
    Feb 2013
    Quote Originally Posted by heaterman View Post
    I won't go into details of pricing, but it is a friend who is an AC guy and he is allowing me to purchase the parts, and charging a flat rate for labor, one for full replace, one for inside(so no markup on parts). That is probably the difference you are seeing.
    What do you mean in the bold part? Altenative coolants that can be added to a system that is running on R-22 now?
    Your advice was REALLY helpful, I appreciate it
    Also if anyone else has an opinion, I would like to hear it, the more the better.
    Aug 2012
    Your best move at this point in time is to change all of the equipment because as you say 410a will be cheap for yrs to come.
    If you are buying the equipment on line ( which I am not assuming, just fyi) warranties are voided.
    R410a units are more effecient than r-22 units and you can have a 10 yr. parts warranty if bought thru a contractor and registered properly. I believe that total replacement is in your best interest.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Feb 2013
    Quote Originally Posted by toocoolforschool View Post
    I was looking at purchasing online and having it shipped to me. I really don't want to pay some contractors insane markup for the same product. Is there a way to purchase it somewhere with a warranty and not get raked over the coals?
    Also, yes the 410 would be cheaper, but is that of a huge concern to me if my AC is in working order?
    Jun 2006
    Richmond, VA
    Quote Originally Posted by jakek34 View Post
    How's not having a warranty on the indoor part working for you now???
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Aug 2012
    So you really think you are purchasing equipment online and not paying a markup?
    Chances are you are making a mistake if you follow your current direction.
    You have lost most if not all credibility from here on out.
    Feb 2013
    I don't think I merit being ridiculed based on the fact I'm not rich and can't afford certain things. Also I don't think they make warranties for 25 year old products, but I could be wrong.
    Feb 2013
    I guess what I need to find out then is this...are there companies out there, and can you suggest some, where I can buy the proper equiptment the proper way and make sure I am covered by warranties while also not having to pay an arm and a leg? I just don't want to become one of those horror stories I hear where people WAY overpay for product because they do not know any better.
    I honestly can't understand why people have to treat me like this. I'm trying to gain knowlege, trying to do things the right way, and instead am told I am not credible and basically stupid? I came here for help from people I thought were genuine and trustworthy, not to start a fight.
    Feb 2013
    Also let me add, when purchasing it online, it is from a company, not an individual or ebat etc. I assumed me buying it online YES I would be paying a markup. I just have someone who can do the work cheaper for me, but still want the RIGHT product.
    Maybe there is a disconnect there in termonology?
    Here is one of the site's I have been looking at, is this credible or am I going about this wrong?
    Removed purchase site
    This companies warranty says...We back all manufacturer warranties on equipment, the equipment must be installed by a heating and air contractor or approved by HVAC technician. When a part needs to be replaced we will ship you the replacement part and then you will return defective part back to us for warranty reimbursement. We back all manufacturer warranties on parts only, the customer is responsible for the shipping and labor charges to replace defective parts.
    Jul 2010
    nebraska
    If you were my customer we would suggest just replacing the air handler.
