Results 1 to 7 of 7
    rheem heat pump frozen
    i have the heat pump with demand defrost running in steady light rain, wet, working fine at 32 to 34F degree outside, good heat to keep indoor 71F, heard compressor each cycle about 15 to 20 minutes long, ran twice per hour, and then overnight into morining, still more light rain, temperature slowly raised to about 35F or 37F outside, and heard compressor running non-stop, like 50 minutes long. went outside, and saw there was a good amout of frost on outdoor fins and looks like not defrosting.
    did the demand defrost control just terminate defrosting when outdoor temperature is greater 35F? or just a bad combination of running heat pump in light freezing rain at 35F, where demand defrost not able to hand it either.
    is there a manual defrost on demand defrost system?
    turn off thermostat and run garden hose to rinse the frost on coil fin?
    or put on coat and run AC for a few mintues?
    thanks
    Sep 2012
    Missouri
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    Jan 2005
    Emerald Coast
    It got behind. Freezing drizzle (precipitation) is not welcome on a heatpump.
    Switch to backup heat till the drizzle / ice is over with. It can't keep up.
    Do not attempt vast projects with
    half vast experience and ideas.
    There is a manual (test). Only problem with switching to cooling is the fan keeps running pulling cold air over the coil. Won't defrost much that way.
    Demand boards do let the coil get very frosty before going into defrost.
    Northeast Ohio
    Don't panic yet. Frost is one thing, frozen solid is another. Let it do it's thing.
    Lancaster PA
    JES, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Tallahassee, FL
    There may be an way to make it defrost longer if in fact it is functioning properly.
