    Feb 2013
    Question Global data Transfer XBS > EBI
    Im not sure if you know about Excel Building Supervisor (XBS).
    XBS have this tool global data transfer (attached) this function you can command a few points that are in manual mode.
    In the picture when AV_7_L4_129_2P goes to 1 then the Receptor Potins goes to 1.
    We are migrating this site to EBI software.
    Could have this tool or something like that in EBI ?
    Regards
    Caio Grecco
    Oct 2007
    England
    Quote Originally Posted by caiomml View Post
    Regards
    Caio Grecco
    Yes, but you will have to start learning how to write scripts in the EBI environment. I wish you luck, you are going to need it.
    Who is doing the migration? If its Honeywell, then the engineer doing the work should be able to get assistance from the Technical department.
    Keith
    Feb 2013
    Quote Originally Posted by Keith D View Post
    Keith
    Keith,
    I'm doing the migration my company is an integrator from Honeywell in Brazil.
    I have knowledge with scripts in HMI Web and Server Scripts.
    Do you work with EBI a long time ago ?
    Regards
    Oct 2007
    England
    Keith,
    Then you are probably going to know alot more than me, Its a bit of a while since I last wrote one of these.
    And I dont have ready access to SymmetrE or EBI to try them out anymore.
    I may have a backup somewhere with some on.
    If you are desperate I could have a look. I cannot say if they will be of use to you, but they may be some sort of guidance.
    Keith
