Results 1 to 11 of 11
    Las Vegas, Nevada
    Thumbs up One Possible Alternative
    In other threads we discussed ideas for solutions to different problems. Go see what the boys at Ben & Jerry's have been up to. A poster in the Refrigeration Section offered up this link. Say what you will about their political stance, at least they're not afraid to try...
    http://www.benjerry.com/our_company/sounds_cool/
    The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
    Aug 2001
    forney texas
    Hmmm. interesting. but what is the magic liquid.
    Las Vegas, Nevada
    I don't know. Glycol, maybe?
    Aug 2001
    forney texas
    and what about a change of state, how else would you absorb or reject heat.
    Las Vegas, Nevada
    I'm not sure. It looks as though they may have eliminated the need for "Change of State" as we think of it. Fellas, if this technology proves out, our entire industry is about to go through it's own "Change of State". Might not be a bad thing.
    Aug 2001
    forney texas
    with one liquid hot all the time and the other cold all the time I don't see a transfer.
    Las Vegas, Nevada
    The transfer appears to take place in the Plates via conduction.
    Aug 2001
    forney texas
    It looked to me like the plates were keeping one cold and the other hot
    It's an interaction between sound and heat.
    If the sound waves are manipulated in the right way, heat can be moved around.
    Souped up sound/pressure waves with an inert gas as a medium.
    Cool indeed.
    Aug 2001
    forney texas
    It will be interesting if it ever makes it past research. From what i can see, the system needs a computer to make it work and the prototype was immense in size for a small novelty box and probably had a seer rating that did not quantify mentioning
    Quote Originally Posted by acmanko View Post
    Think of it as a chiller system with a glycol loop on the condenser. You have glycol looping through the cold plates and the case cooling the case and a glycol loop on the hot side cooling the "condenser" and going through either a fan coil or water heat/x to get rid of the heat.
