Results 1 to 10 of 10
Thread: HVAC Pro
02-25-2013, 02:49 PM #1
- Aug 2011
- Denver PA
- 22
HVAC Pro
I recently replaced my old XP laptop with a new on with Win 7 32 bit and Win XP mode on it.
I was told that HVAC Pro will not work in Win 7 so I installed in the XP mode.
After installing the HVAC Pro that I had I discovered it is only ver. 8.06. I went back to my old laptop and check and had ver. 8.08B on it.
I could not find that software anywhere in my system. I do not remember where I got it from. I do have the patch that goes with it for usb connection.
Does anyone have an updated ver. of HVAC Pro that I could get?
Willys
02-27-2013, 07:52 PM #2
You'll probably have to purchase the upgrade unless you can find the disc.
02-27-2013, 09:30 PM #3
02-27-2013, 09:40 PM #4
By the way, hvac pro does work on win 7 professional 32 bit. I find it annoying using the win xp mode in win 7 which to me is garbage, but each to their own. The icons look different on the menu and desktop, but the program when opened looks the same and operates just fine. At least it does on my laptop, seems like some people have been having some problems. I use a dell vostro laptop.
" Good labor is not cheap and cheap labor is not good." MN
03-01-2013, 09:26 AM #5
- Nov 2006
- Desert Southwest
- 369
If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
No good deed goes unpunished.
If you want to take off friday to go fishing then make sure you train your helper right.
03-01-2013, 11:39 AM #6
- Aug 2011
- Denver PA
- 22
I did load it first in Win 7, but did not get to try it. Than another tech in our office said it will not work. Thanks for the info. Have been contacted by someone that is willing to share ver. 8.08, when I get will it will try again.
03-01-2013, 01:33 PM #7
- Feb 2005
- Edmonton, AB Canada
- 509
Good day All,
Just to clarify... HVACPro will not run natively under Win 7 64 bit... You must use XP Mode (only available with Win 7 Professional and Ultimate) or another Virtual Machine running 32bit Windows.
Cheers,
Sam
03-02-2013, 03:43 PM #8
03-02-2013, 06:44 PM #9
- Feb 2005
- 509
03-04-2013, 02:04 PM #10
- Aug 2011
- Denver PA
- 22
Thanks everyone for your thoughts and help. I got the file and reinstalled everything and test connected to a controller in the office. All went well.
