Results 1 to 13 of 14
    May 2005
    need a condensing unit for a weber coffin type freezer.(weber)
    weber is out of business and the condensing unit is wrong and really old heres some numbers:
    unit: weber coffin type freezer # C-TV-12IC/ Ser#1R102816
    compressor is a 90-1.50 a medium temp compressor
    the condensing unit really needs to be trashed..freezer is 60' away from condenser and line sets are under ground.
    like all my customers this guys broke.
    Jul 2000
    Cuenca EC
    I couldn't even find a mention of Weber, so no info seems likely.
    Based on single deck frozen food or ice cream case from 30 years ago, they generally required 450-500 Btuh/ft so between 5400-6000 Btuh at -25F SST for frozen foods (or -35F SST for ice cream) should work OK for a 12 footer.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Las Vegas NV
    Quote Originally Posted by primmers View Post
    Is this a Copeland semi-hermetic compressor? If so it is from the 60's with that part number 90-150. The current compressor number is an EAB?-015A-??? which is a MT12 or LT502 compressor.
    May 2005
    this icemeister ill look for one..
    May 2005
    yes powell it is a semi compressor, this place is a mess, and was put together with junk
    he knows i won't continue the practice..and will replace the condensing unit with what is correct..
    Las Vegas NV
    The 90-150 (EAB-0150) is a MT12/LT502 compressor as I stated but the LT502 use is an alternative application for which I cannot find any btuh specs.
    Based on it's CFH and the S.W.A.G theory I would guess it's LT502 btuh's are very close to what Icemeister listed.
    May 2005
    got a quote today for $2755,,,,MY CUSTOMER IS GOING TO COUGH UP HIS LIVER..
    Jul 2000
    Cuenca EC
    I've had very good experience with the newer hermetic low temp units...and they save a boatload of money.
    Look at a Copeland FJAL-B301-TFC.
    May 2005
    wii do, thanks.
    May 2005
    Quote Originally Posted by icemeister View Post
    ice, i cut find any info on this model number..
    Jul 2000
    Cuenca EC
    Here's a link to the Copeland info (See p.9): http://www.hvacrinfo.com/CopelandUni...DS-4_MandF.pdf
    May 2005
    wow a 3 hp system.....Ok, thanks..
    Jul 2000
    Cuenca EC
    A 3 HP unit does appear to be big for this application...if you're comparing it to what the semihermetics will do...but going by the estimated loads I stated of 5400-6000 Btuh at -25F SST for frozen food (or -35F for ice cream) the FJAL-B301 would be the one to go with.
    While the FJAL-A225, at a rated 5380 Btuh at -25F SST is a tad shy of what we need for FF, it's close enough that it might work OK...but I'd feel a lot better with a little extra, especially when you consider that we're taking a wild guess at what the load really is for that old case.
