    Feb 2013
    LuxPro Thermostat
    On a LuxPro thermostat, one of the terminals, labeled R. It says "transformer, switched side, single source" in the manual as the typical connection. Does that mean its the power connection?
    SW FL
    LuxPro provides several t-stats.
    BUYER BEWARE...
    it's not hard to destroy an Expensive control board
    when redoing wiring or changing out t-stats.
    Designer Dan
    Feb 2013
    its an old psmh45 with mercury.
    SW FL
    Quote Originally Posted by raleighgirl86 View Post
    You most likely need Pro assistance with a replacement.
    Honeywell RTH230 or similar
    http://www.honeywellcentral.com/prod...mostat-rth230b
    Owner beware.
    http://www.luxproproducts.com/support.html
    Designer Dan
