Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 70
    Jul 2009
    Kansas
    I like both except I only use a b tank on big installs with lots of brazing. I carry a turbo torch hooked to an MC bottle and a oxy-acet torch. Small repair on a good day just grab the MC and turbo less weight and cheaper. It really depends on what your doing but if just starting out for a first torch for most repairs oxy-acet would be the one to get.
    Eugene, Oregon
    More control with the Oxy/Acetylene. Make sure to get a rosebud for large pipes that require a lot of heat.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Oxy/acetylene is my pick. Although I also use mapp gas and staybrite in the attics most of the time.
    Nov 2009
    Central Virginia
    I use B-tank for everything. Just my preference.
    Sent from my SPH-D710 using Tapatalk 2
    ____________________________________________
    If you don't know what you are doing.... ASK!! There is no such thing as a "Stupid" question.... Maybe.
    Feb 2012
    Toronto Canada
    What # tip do you guys use when using oxy/Ace ?
    Jun 2009
    Upstate SC
    Quote Originally Posted by OldSchoolMech View Post
    #2 for 3/8 and larger. #0 for smaller.
    Sent from my SCH-I510 using Tapatalk 2
    Dec 2011
    North Texas
    Quote Originally Posted by fliks View Post
    Same here.
    Oct 2012
    Where we mow our own grass
    So I am going with oxy/Ace I just orderd it.
    Attachment 360721
    Coming from Ottawa to Toronto should be in tommorow.
    The deposit on the bottles is insane more then the torches FML
    I have the same setup, and I'm very happy with it. I use the #2 tip for almost everything 1/4" thru 7/8".
    Atlanta GA area
    Quote Originally Posted by jdblack View Post
    Quote Originally Posted by Mike19 View Post
    Agree... mostly #2 tip. Change to a rosebud if I need to do some serious heating. Also have a circular (forgot the name) tip for RV valves... although I have not changed an RV in years. Usually condemn the unit... customer is happy to get a new system with a 10 year warranty...
    GA-HVAC-Tech
    Apr 2010
    California
    Oxy/Act, from day one in the buisness. I did also carry a map gas turbo torch for a back a up. The thing with the little M/C kits, is you can weld, cut, and solder or braze on anything, for a limited time.
    Wayne
    Jun 2008
    In the Boondocks near Marion, IN
    #0 tip Oxy/Acetylene
    i carry the oxygen acetylene rig. tried the B tank... tried just the mc tank. no joy.
    i always use a rose bud tip lol and %5 rod cause %20 cost is just way out of hand these days.
    Jan 2001
    Do the victor torches accept specialty uniweld tips
