Page 1 of 6 123456 LastLast
Results 1 to 13 of 70
    Feb 2012
    Toronto Canada
    The great debate..B-Tank or Oxy Ace Torch.....What do you use?
    I am buying myself a torch Tommorow (Before Wed). I have used B tanks with success inside as soon as I have to go outside I gotta block the wind etc. I did not pick the tip size nor did I buy it. I have also used it in school with a rose bud tip and was not a fan. I have also used oxy ace in the field as well as at school. It is way faster and hotter. You can blow a hole in the copper if your not careful. It cost more cause you need 2 bottles.
    Do you guys just think I didn't have the right tip for my B-Tank? Should I even bother with that route?
    I wanna hear from you guys I will be doing mostly resi installs and commercial repairs.
    I work on roofs 75% of the time so I need the tote to carry it but not the cutting handle. Does anyone know the Turbo Torch model # for the oxy ace torch kit with tote and no cutting handle?
    May 2012
    Upper Michigan
    I preferred a b tank, I'm not sure what tip I had but it was similar to a map gas torch tip. I hated using oxy acetylene.
    Central NJ Area
    I prefer b-tank my self. I have Millermatic Mig welder and a plasma cutter for serious situations. I confess that i do have one of those small Mao gas setups from Lowes which i use for small soldering repairs which is definitely hand in some situatiosn!! Funny thing was that i was using at a customers home we put a Peerless Purefire systems and i needed to change a Taco Circ pump and his some was the one that developed the tools lol!! He gave me a case of the yellow map gas cylinders! SCORE!!
    Jun 2009
    Upstate SC
    I've never used a b tank. Im happy with ox/act. I use a 0 tip for small stuff and a 2 tip for 3/8 and larger.
    Every b tank I've seen had a big tip and handle. I don't see how you could get into tright spots with that.
    Sent from my SCH-I510 using Tapatalk 2
    Air/acetylene is for plumbers!
    In all seriousness, I've got no issues with air/acetylene, especially since they started making tips for them that don't require hearing protection to use, but you will still need an oxy/acetylene torch for a lot of types of leak repairs, and other work.
    Jul 2009
    Columbia, MD
    i used b-tank with #14 tip when in residential.
    now that i do commercial i used oxy/act with #0, #2, and #15 rosebud.
    if you had to pull a distributor apart you would need a nice rosebud. if you used a btank it would take to long to heat up and the distributor tubes would start to come off.
    when repairing evap coils i use the #0 tip with great success.
    when doing big r/v 1-1/8" you will need oxy or you will burn it up.
    when doing a compressor changeout, i may use my turbo with #14 tip. it depends.
    hope this helps.
    Jun 2009
    Upstate SC
    Oct 2011
    Chicagoland Area
    oxy/act for me
    Oct 2010
    Quote Originally Posted by 2sac View Post
    oxy/act for me
    Same here.
    Atlanta GA area
    oxy/act for me
    Add me to this group...
    More temp control with Oxy/Acet with #0, #2, and rosebud tips... However
    I suspect it is more what someone learned on and is used to.
    I do agree that a torch that sounds like a jet engine is not a good idea...
    Ga-HVAC-tech
    Feb 2012
    Toronto Canada
    So I am going with oxy/Ace I just orderd it.
    Coming from Ottawa to Toronto should be in tommorow.
    The deposit on the bottles is insane more then the torches FML
    Atlanta GA area
    Quote Originally Posted by OldSchoolMech View Post
    Bottles cost lots of $$$... govt regs and all that stuff.
    I have an extra O2 and Acet in my van... hate to run out.
    Ga-HVAC-tech
    May 2009
    Earth
    Dittos to the Oxy/Acet, a big roaring B tank flame burning every thing with is 6" and overheating parts during the long heat process is not for me.
