Results 14 to 20 of 20
Thread: TXV all the time?
02-24-2013, 09:20 AM #14
The reason they show the same efficiency with or without txv is they only run test at 1 set of conditions.
And my txv systems have been reliable. They can extend compressor life too. Unless its a recip w/o start kit.
02-26-2013, 12:55 AM #15
- Oct 2012
- Sacramento,ca
- 171
Its amazing how different things are in other parts of the country. I haven't installed anything with a fixed orifice in nearly 7 years. Our regulations are quite stringent around here where 15 seer is now considered standard efficiency and no bleed txvs are mandatory on anything new. Also i must be lucky because i have not had a failed txv in any of the 200 plus systems i have installed but i know its probably coming one day. All txv failures i have seen are installer caused mainly by bad pump down and purging techniques.
02-26-2013, 09:29 PM #16
- Jun 2001
- Oklahoma City
- 2,591
Not wet ragging a TXV when you braze the lines will kill one pretty quick.
02-26-2013, 09:54 PM #17
Professional Member*
- Sep 2005
- North GA
- 17,285
ALWAYS use a TXV... one of my minimum requirements... Like ALL coils get a float safety switch... no exceptions.
The only TXV issues I had were the Rheem/Ruud coils in 2010... only had 2 bad ones... both of them replaced under warranty and I got labor to change them.
TXV's, like anything else, have specific details which must be followed for them to work properly and last a long time. I prefer to REMOVE the bulb when brazing... then replace it a half hour later when the suction line is cool. On Rheem coils the bulb is loose from the factory... so it will be mounted after brazing. The TXV issues I have repaired were mainly due to improperly mounted bulbs.
I do not mean this to be rude... however I really cannot understand why it is sooo hard to understand how to mount a tXV bulb... The ides is for the liquid refrigerant to STAY in the bulb... so mount it so the line is UP... how hard is that?
TXV's are a great thing... methinks the only reason they are not universal on residential AC is cost.
BTW: How many pistons do you see in refrigeration... <grin>GA-HVAC-Tech
2 Chronicles 7:14
02-26-2013, 10:09 PM #18
I use pistons and txvs depending on what seer/eer I'm trying to get with a given match. Most of the York's we install will get 15 seer with a piston and that's all we need for the utility rebate around here and it saves $X for the customer. Of course I give them their options and inform and the customer chooses lots of times the cheaper option.
03-19-2013, 09:54 PM #19
- Nov 2011
- Phoenix,AZ
- 95
We use some piston systems its one less thing to go wrong.
03-19-2013, 10:24 PM #20
- Jun 2009
- South Carolina
- 116
Agree with you on this one.
We also had a few ruuds where the txv messed up but it could have been our install crew not gonna lie.
sometimes it takes a few kick in the a** and some in a even more tender area to figure out what is going on.
But as of right now piston if we can but we basically sell the lower seer units because units might last 8-10yrs when they are less than 50 yds from the end of the dunes. Saw one yesterday you can not service the unit on high tide because you would be standing in the ocean. And with the crazy floods or big waves it probably splashes the unit.
2009 coil will be gone in another year.
