02-23-2013, 07:44 PM #1
- Feb 2013
- 9
Johnson FX-PCT Programming and Commissioning Tool software
Can anybody answer this, I just downloaded a new FX-PCT programming and commissioning tool from Johnson controls. The very first page top left has the 'configure' and 'commission' tabs and the top right has the 'select system' and 'define hardware' tabs, for some reason the 'commission' tab is the only one that allows access in the program and commission only. I'm trying to configure a new controller and the 'configure', 'select system' and 'define hardware' tabs don't allow access.
Anybody have the same problem with this?
02-23-2013, 09:47 PM #2
- Nov 2005
- Shreveport, Louisiana
- 2,240
You were sold the commisioning only version...
UA Local 141
02-24-2013, 03:04 PM #3
- Feb 2013
- 9
i think your right!
cheers
02-25-2013, 12:42 PM #4
- Feb 2013
- North Carolina
- 13
When you go to first install it you should have the option to choose the full version or the commissioning only version. Make sure you installed the full version.
02-25-2013, 04:40 PM #5
- Feb 2013
- 9
thanks! this works.....
cheers
