    winston salem
    Smile Goodman gas furnace coil drain pan melt
    Has anyone ever seen a melted drain pan in a gas furnace, well i went out on a call and the pan was melted, the high limited didnt kick out before it melted on a goodman. we replaced everything and it did it again, goodman representative came out and couldnt figure it out. I have some ideas, what do you thing. thank you steve
    Nov 2000
    Eastern PA
    Plastic drain pans have a melting point. If that point is exceeded, there is something wrong. What is the temperature rise of the system? What type of system? Filtration?
    There are millions of plastic drain pans on furnaces, so you need to look for why the problem exists.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Newton, NJ
    I have seen it when there is a hole in the heat exchanger. Also you should check the static pressure, airflow, temperature rise, gas pressure and combustion. These measurements should point you directly to the problem.
    N.E. Ok.
    What color was the drain pan, white or grey?
    There was a pan not rated for high temp. that i believe was white. Long shot as it's been quiet some time since i have seen one. melted that is.
    Nov 2000
    Eastern PA
    Quote Originally Posted by captube View Post
    Yer right. That drain pan was designed for use in air handlers only. I thought they were the black ones.
    N.E. Ok.
    Quote Originally Posted by RoBoTeq View Post
    They are black if installed on a gas furnace joking.. they may be black.
