Page 9 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 105 to 117 of 196
Thread: Boiler Question
  1. #105
    Mar 2010
    Morgan Hill Ca.
    Quote Originally Posted by MHall View Post
    Interesting information. Would co-generation, require a boiler? Based on what others have said I always thought that emissions would be a great part of why new buildings don't want a boiler on the property. Isn't live steam dangerous as well?? I find it hard to believe that a new LEED hospital will use steam for space heating. Wouldn't that require a boiler operator on site 24/7??
    I thought the sears tower had electric boilers for hot water heat?? This is another example of an older building which utilizes hydronic heat. If it had been built in 1993 rather than 1973, it would have electric heat strips. No hydronics.
    They might also have heat recovery chillers. I read the specifications sometime ago, and don't remember for sure
    Sears Tower (now Willis Tower) uses Co Gen for heat because of energy consumption concerns...... The generation of electricity heats the building.
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
  2. #106
    Mar 2010
    Morgan Hill Ca.
    What exactly do you mean by that??
    You need to tour a hospital...
    Hospitals operate 24 hours a day... There has to be an engineer on site when it is open for business, which is, 24 hours a day.
    Steam is the obvious choice because they have to heat their domestic water supply to over 140*F to kill off any potential bacteria and whatnot then temper it down to useable temperatures. Hospitals also do a lot of laundry and the use of autoclaves use a lot of steam.
    It make perfect sense....
    What do you mean by "exactly"?
  3. #107
    Nov 2010
    Quote Originally Posted by GT Jets View Post
    You would not see a new hospital heated by steam. Think of the lawsuit of a patient burned themselves on a radiator/unit ventilator .Plenty of older hospitals using it though.
    And by older, I mean pre 1982.
  4. #108
    Jun 2006
    http://www.broaddusassociates.com/in...nter&Itemid=51
    There's a nice new fairly new hospital built in your neck of the woods. Maybe you should call up the architects and engineers and tell them they made a mistake. They installed (3) 400 HP Boilers.
  5. #109
    Nov 2010
    Quote Originally Posted by timmy2734 View Post
    Interesting. When I stated that; "no new buildings use boilers", I was refering to space heating. Perhaps, they are doing that here?? More than likely its for laundry, sterlization, or domestic water.
  6. #110
    Jun 2006
    So you're an engineer designing a building....you have an abundance of steam in your hand...but you'll install electric strip heating ?
  7. #111
    Mar 2010
    Morgan Hill Ca.
    There are quite literally dozens of ways to heat with steam. Only one of which are radiators.
    More homework.......
    You can use heat exchangers to heat water, turn turbines and heat with the condensate, heat water with flue scavengers.
    All of these practices are used TODAY
  8. #112
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    Even, in new buildings??
    Our design temp is -23f. We see -40f. That's actual temperature, not windchill. Natural gas is 60-70% cheaper than electricity.
    I love my job, but paydays Thursday
  9. #113
    Mar 2010
    Morgan Hill Ca.
    Quote Originally Posted by rich pickering View Post
    You my friend need to friggen move... At what temperature does Vodka freeze?... Holy crap.
    All of your tee shirts must have nipple holes torn into them.
  10. #114
    Mar 2010
    Morgan Hill Ca.
    OK, just looked it up....100 proof Vodka freezes at -40*F...
  11. #115
    Nov 2010
    My previous question has not been answered.
    Are heat recovery chillers ever installed in newly constructed buildings?? As I stated before they seem pretty rare in general.
  12. #116
    Mar 2010
    Morgan Hill Ca.
    Not that it matters much, you don't seem to listen to the answers anyway....
    https://docs.google.com/viewer?a=v&q...4R58GZg0FEWMaw
    They will eventually gain popularity as systems get more elaborate.
  13. #117
    Jun 2009
    Northwest IN/Chicago
    Thank you for taking the time to offer an explanation. As I said earlier I am not trying to come across as disrespectful, I am just attempting to research my question thoroughly before jumping to an agreement with what one or two people say.
    Those I’ve spoken to personally give the impression that boilers and hot water/steam heat are old technology installed in only older buildings. Those here, argue otherwise. I am just trying to look at both sides and discuss this intelligently.
    Still, I find it very hard to believe that a brand new hospital would use live steam for heat. That would mean an operator has to be present 24/7. Are you sure this isn’t a renovation of a much older building??I thought the goal in today’s economy was to avoid a large onsite staff?
    And with LEED certified buildings dominating new construction, steam seems the least likely choice for something new and efficient.
    Again, I’m not trying to argue. It just seems I’ve now been told two things……..
    You sure must really trust the people that have convinced you that hydronic heating is of the past! They probably were messing with you, or high. Or both.
    If you had actually done some research on your own I think by now you'd stop insisting that electric strip heat is the way of the future!
    Oh and BTW, steam heat is a very efficient form of heat (when tuned properly). It can run circles around forced air (referring to gas furnaces there, not to be confused with hydro air), less then stellar hot water systems and for surely electric strip heat
    There is absolutely no possible way in a million years that strip heat would have been used. Not in 1973, not in 1993, and NOT NOW.
    Don't they use WSHP's for cooling? and I guess the Co Gen is keeping the loop temp up for the WSHP's. Or maybe it's all different then I've heard?
