Results 79 to 91 of 196
Thread: Boiler Question
02-26-2013, 01:40 AM #79
Very eloquent.
Your are correct, however....
He uses the terms "all newer building have strip heat", this is bunk....
He uses the terms "boilers are being phased out due to install costs" again, bunk.
And I totally agree with you, he needs to tour about a half a dozen LEED platinum buildings and get a feel for the direction that the building industry is heading.
That is my argument in it's entirety. BTW, did you see the electrical statistics on the Dallas bank building? Holy crap Batman! In California you could run three city blocks off that badboy...
GTIf a day goes by and you have learned nothing, I hope you got a lot of sleep.
02-26-2013, 01:44 AM #80
- Nov 2010
- 166
As I stated earlier anything built 1981 or prior usually has a full central plant system including steam or HW heat provided by boilers, district steam, and heat recovery chillers. Anything built after about 1982/3----to the present seems to utilize electric heat, hence the examples I listed. I could show you brand new properties and you would see DX units and electric heat.
02-26-2013, 01:52 AM #81
- Jun 2006
- 248
02-26-2013, 01:52 AM #82
The highlighted area is where you lose me completely... This information is wrong for MOST areas of the country... The DX units you are mentioning are more than likely going to be heatpumps.
Look up FHP (Florida heat pumps) these are water to water heat pumps. Also look up CHP (California heat pumps) these are water to air systems. Both considered DX when loosely translated.
When done correctly, these systems can be crazy efficient and provide an almost perfect environment.
As stated before, you would never get a building permit here in Silicon Valley for all electric heat... Not in a million years. This is why I am so passionate about letting you know that what you are saying is not accurate. If you ever move out of Dallas you will be totally lost.
02-26-2013, 02:07 AM #83
- Nov 2010
- 166
02-26-2013, 02:23 AM #84
- Jun 2006
- 248
I've never seen one.... Surely you could use it to preheat your water, but I think that you'd still need a dedicated hw heater.
found some reading material
http://www.mcquay.com/mcquaybiz/lite...er-HeatRec.pdf
http://www.johnsoncontrols.com/conte..._%28510%29.pdf
02-26-2013, 02:29 AM #85
This is actually the beautiful part about WSHP systems, lets say I had twenty heat pumps heating and 15 heat pumps cooling, I would not have to inject any heat nor would I have to reject any heat. I would simply be taking the heat from once space and moving it to another.
I know that is not what you are referring to, but it works out the same.
It is not (as far as I know) a widely used system because of the small window of utilization versus the expense and maintenance involved. You need to have really warm condenser water to be able to get much use out of it, and that takes most modern chillers out of their "comfort level" as far as efficiency. Think about it this way, most newer chillers like the coolest water possible for the condenser (in the low 70's), raising that temperature enough to gain much sensible heat out of it (high 80's) would likely negate any gains from recovering the heat.
Hope I didn't con-volute the crap out of that, I get the feeling I did.
There are chillers specially designed for this use and I don't think the total efficiency is there yet.
What seems to be on the cutting edge these days is in the refrigerant side for economizing with liquid refrigerant. The biggest issue so is the vast quantity of refrigerant required to accomplish it.
02-26-2013, 02:36 AM #86
- Nov 2010
- 166
02-26-2013, 02:44 AM #87
You are very welcome.
Just one last jab before I go do a high intensity light filtering eyelid performance check...
If you have a heat recovery chiller (duplex condenser) you have to have a hydronic heating loop regardless, so technically speaking this would be a great retrofit to an existing building with separate systems. Especially if there is a really consistent load on the chiller (like a manufacturing facility with office space).
02-26-2013, 02:53 AM #88
- Jun 2009
- Northwest IN/Chicago
- 249
You have said this a couple times but you can't be more specific as to WHERE your referring to? Is this a blanket statement for the whole country or are you referring to your city Dallas? and have you actually seen these electric heat strips your talking about or are you taking somebodies word for it?
I can think of at least one building built before 1981 that does not have a "full central plant" and that would be the Sears tower (Or Willis tower as you probably only know it as at this point). It has water source heat pumps (I haven't seen this for myself, but have heard this from quite a few techs around this area). That was completed in 1973.
02-26-2013, 06:16 AM #89
Requirement is based on boiler horsepower. 30 hp and greater. hense the ohio special only 29 hp
ckartson
I didn't write the book I just read it!
02-26-2013, 10:14 PM #90
- Nov 2010
- 166
02-27-2013, 12:33 AM #91
- Jun 2006
- 248
No worries. It is performing the same function though. It's all just going into a heat exchanger.
Have you ever checked out tecogen chillers?Last edited by timmy2734; 02-27-2013 at 01:03 AM.
