Results 1 to 13 of 196
Thread: Boiler Question
02-23-2013, 05:44 PM #1
- Nov 2010
- 166
Boiler Question
As a High School student hoping to get into the field,I have been doing some additional research on boilers.
One question I have is this; "Under what conditions must a boiler be under a 24 hour watch?"
Both schools I have attended use boilers for hot water heat, and only have staff present during the day.
Thank you for your time and assitance in answering my question.
02-23-2013, 08:43 PM #2
- Jun 2006
- 248
It depends...
Around here, if a low pressure boiler is fully automated, it does not require an operator. Hi pressure boilers require an operator during operation.
If a facility is a 24/7 operation they'll have somebody there. Something like a school may not as they would shut down daily and nut run around the clock.
02-23-2013, 09:04 PM #3
For the most "all encompassing" answer, refer to the rules set by each state.
https://www.google.com/search?q=Stea...ient=firefox-a
Asking questions is a great way to expand your knowledge.. If I may be so bold, aim higher than you think you can achieve.
A person that sets a low goal will achieve their goals easier but will find them less rewarding....
GTIf a day goes by and you have learned nothing, I hope you got a lot of sleep.
02-23-2013, 09:49 PM #4
- Nov 2010
- 166
02-23-2013, 09:54 PM #5
02-23-2013, 10:05 PM #6
- Nov 2010
- 166
Is an operator required for both Steam boilers and hot water boilers??? I always thought that operators were required with steam only...?
Thanks.
02-23-2013, 10:15 PM #7If a day goes by and you have learned nothing, I hope you got a lot of sleep.
02-23-2013, 10:21 PM #8
- Jun 2006
- 248
the word "operator" gets tossed around too easily. There's some guys that are nothing more than switch flippers unfortunately... or sometimes maybe management has them doing other things that they feel are more important.
then stuff like this happens
http://www.ipemaritimes.com/bxpl.pdf
NYC Department of Buildings requires a licensed engineer for hi pressure boilers.
NYC Fire Department handles the low pressure boiler operation. There's also a DEP Air pollution certificate for residual fuel oil.
02-23-2013, 10:24 PM #9
- Nov 2010
- 166
See above.
02-23-2013, 10:25 PM #10
- Nov 2010
- 166
Thanks for the replies.
Another question I have; " Are high pressure boilers used only in older properties"?? It seems that this method of heating hasn't been used in new construction for 30+ years. Are there any newer buildings that utilize this type of heating??
Currently, all new construction appears to be electric heat strips. I would appreciate your insight. Thanks
02-23-2013, 10:28 PM #11
- Jun 2006
- 248
nope.
You'll see it still in New construction.
Hospitals, Colleges, large apartment complexes, utility companies, factories.
It's still around
02-23-2013, 10:48 PM #12
- Nov 2010
- 166
How new?? I've never visited any building heated by steam or hot water, that wasn't 50+ years old.
However, I have read case studies of buildings built in the 1970s that used boiler heat. It is my quess that boiler heat fell out of use in the early 1980s, from then on it was all electric heating elements in new construction. Am I right?
This is simply my theory, from the limited obsevation I have as a high school student. Any additional input is appreciated!
02-23-2013, 10:58 PM #13
Much has to do with what part of the country you are in, gas, electric, oil, propane. I see steam boilers going in brand new buildings....mostly hospitals. Steam is very efficient, no pumps..per se.
I think steam is a lost art because so many people are scared of it and do not understand how a simple steam trap works. Therefore they do not get maintained resulting in comfort issues.If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
