Page 14 of 16 FirstFirst ... 478910111213141516 LastLast
Results 170 to 182 of 196
Thread: Boiler Question
  1. #170
    May 2012
    Upper Michigan
    Quote Originally Posted by meplumber View Post
    I was done with this thread and THIS CHILD after my third attempt to tell him. He doesn't want to listen, so why waste anymore time on him.
    Ya I seem to recall when I was in 12th grade I knew I all, I think we have a case of that on our hands lol
  2. #171
    I also mentioned that about anything new built in Indy is on district steam & chilled water. I gave the example of the new city hospital. 3 boilers are being added to a new central plant and the building will be tied to the existing steam & chilled water lines. Also 4 of the 5 Marriott hotels just built including the worlds largest JW Marriott are on the steam & chiller loop. Lucas Oil Stadium which hosted the Super Bowl 2012 is across from the steam plant and served by district energy. The convention center, new IU Health buildings, a large new "City Way" shop & hotel complex just opened... All told, over 200 buildings downtown are heated and 50 cooled by district energy. Many buildings with dying chillers tie into the loop instead of replacing chillers. On Monument Circle, the Circle Tower and the Monument both did that, the World War Memorial, Embassy Suites...
    Yes, I can see office buildings without access to this service doing without a boiler. Many will use large packaged units on the roof instead of boiler/chiller. But as I also posted, most schools built recently do have boiler/chillers. A new Renaissance Inn in our suburb has an air cooled chiller and a couple boiler stacks. Also in our suburb, a new 2 building performing arts center is served by a small district energy plant. City hall and the cop shop tied into it. On a bitter morning, you'll see steam from a cooling tower on plus steam from the boiler stacks.
  3. #172
    Mar 2013
    Central IL
    Boilers over 50# here in Illinois have to have 24/7 monitoring. other wise it is up to the facillities manager. Insurance provider. Small boilers big bombs!
  4. #173
    Jun 2009
    Northwest IN/Chicago
    I've noticed newer low rise office/commercial buildings built from approx 2000 and on utilizing chiller and boiler heat more then buildings built in the 80s-90s. Those I seem to see more DX packaged rooftop systems (with VAV's for zoning)
    This reminds of a story that's not really on topic at all but I feel like telling it anyway, there is this banquet center that has about 30-40 residential split condensers out back, and I assume an equal amount of gas furnaces inside somewhere. I thought somebody had gone mad and paired clusters together for each banquet room. Last year I had gone there for an event, and to make matters worse, come to find out that each split condenser/furnace operated as a SEPARATE system.
    Each single banquet room had 5-10 zones each. There were remote sensors placed every 10 feet on the walls....couldn't imagine what the room with all the thermostats looked like!
    To this day I wonder WTF they thought they were doing.
  5. #174
    Nov 2010
    This quote by the user; "DeltaT" is one of the main statements that convinced me that boilers for hydronic steam/hot water heat are only installed in older buildings.: DeltaT
    View Profile View Forum Posts Add as Contact View Forum Threads
    Professional Member*
    Posts:7,283Originally posted by benncool
    Originally, central power plants were the way to go. Two, 3 or 4 pipe systems were the way. Now it's more or less small water source heat pumps located in the inaccessable ceilings.
    Two reasons for this. Most local codes require a permanent on site building engineer where there are large chillers or boilers. This is expensive. Second, chiller/boiler rooms take up entire floors of space that could be use for rental income. So ceiling mounted heat pumps take up no rental space, just a cooling tower on the roof. And no building engineer needs to be on site.
    So the answer is it depends on when the building was built. Early 80's and before you probably will have central chiller/boilers rooms. After that it's all individual systems located in ceilings.
  6. #175
    Jun 2006
    [QUOTE=MHall;15337141]This quote by the user; "DeltaT" is one of the main statements that convinced me that boilers for hydronic steam/hot water heat are only installed in older buildings.:
    You're right, everyone else here is wrong. This thread can now be closed and destroyed.
  7. #176
    Feb 2007
    Helena, Montana
    Grade on READING COMPREHENSION for MHall........F-
    "Fortunately, I keep my feathers numbered for just such an emergency." Foghorn Leghorn
  8. #177
    Nov 2010
    Quote Originally Posted by ControlsInMT View Post
    I am just going by what an experienced member of the forum stated. If it's not true why did he say it........?
  9. #178
    Feb 2007
    Helena, Montana
    Quote Originally Posted by MHall View Post
    And he followed up with an answer. Funny that you keep changing your ridiculous reasoning when everyone shoots it down. You ego, is definetly second to none on here.
    Ask away, all the questions you want. I for one will never ATTEMPT (since you can't comprehend what you read) to answer one again.
  10. #179
    Nov 2010
    Here is a valid question that I have;
    In going through the TDLR Boiler Records, I have seen many licensed Boilers that are for the purpose of providing domestic hot water. Many laundry centers, hotels, apartments have a "boiler" listed for the purposes of: "hot water supply".
    My question today is; Why are these units called "boilers" when they are doing the same thing a water heater does??? A commercial water heater does not have to be licensed, regulated etc as a boiler does. Why not have a large water heater??
    Any information is appreciated. Thank you.
    PS: The “boilers” listed for providing hot water supply could not too large, as I have seen these units listed as being located in smaller places such as apartments and even restaurants.
  11. #180
    Mar 2009
    Several Miles from Sane
    179 posts ? Reasonable answers to marginal questions.
    I say "Troll" !
    I'm done here .
    If sense were so common everyone would have it !
    All opinions expressed are my own. Any advice provided is based on personal experience, generally accepted fact or publicly available information. As such, it is worth exactly what you paid for it, not a penny more not a penny less !!
  12. #181
    Nov 2010
    User,Cagey57;
    If you read my question, you will see that it is valid and worthy of response. Any replies are greatly appreciated
  13. #182
    May 2012
    Upper Michigan
    User,Cagey57;
    Just like my old boss, "your point was well taken" but zero action or reaction comes of it.
