Results 105 to 117 of 196
Thread: Boiler Question
02-27-2013, 08:46 PM #105
02-27-2013, 08:51 PM #106
You need to tour a hospital...
Hospitals operate 24 hours a day... There has to be an engineer on site when it is open for business, which is, 24 hours a day.
Steam is the obvious choice because they have to heat their domestic water supply to over 140*F to kill off any potential bacteria and whatnot then temper it down to useable temperatures. Hospitals also do a lot of laundry and the use of autoclaves use a lot of steam.
It make perfect sense....
What do you mean by "exactly"?If a day goes by and you have learned nothing, I hope you got a lot of sleep.
02-27-2013, 09:06 PM #107
- Nov 2010
- 166
02-27-2013, 09:08 PM #108
- Jun 2006
- 248
http://www.broaddusassociates.com/in...nter&Itemid=51
There's a nice new fairly new hospital built in your neck of the woods. Maybe you should call up the architects and engineers and tell them they made a mistake. They installed (3) 400 HP Boilers.Last edited by timmy2734; 02-27-2013 at 09:24 PM.
02-27-2013, 09:34 PM #109
- Nov 2010
- 166
02-27-2013, 09:42 PM #110
- Jun 2006
- 248
So you're an engineer designing a building....you have an abundance of steam in your hand...but you'll install electric strip heating ?
02-27-2013, 10:32 PM #111
02-27-2013, 11:43 PM #112
- Nov 2001
- Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
- 2,367
02-27-2013, 11:51 PM #113
02-28-2013, 12:19 AM #114
02-28-2013, 01:28 AM #115
- Nov 2010
- 166
My previous question has not been answered.
Are heat recovery chillers ever installed in newly constructed buildings?? As I stated before they seem pretty rare in general.
02-28-2013, 01:41 AM #116
Not that it matters much, you don't seem to listen to the answers anyway....
https://docs.google.com/viewer?a=v&q...4R58GZg0FEWMaw
They will eventually gain popularity as systems get more elaborate.If a day goes by and you have learned nothing, I hope you got a lot of sleep.
02-28-2013, 03:42 AM #117
- Jun 2009
- Northwest IN/Chicago
- 245
You sure must really trust the people that have convinced you that hydronic heating is of the past! They probably were messing with you, or high. Or both.
If you had actually done some research on your own I think by now you'd stop insisting that electric strip heat is the way of the future!
Oh and BTW, steam heat is a very efficient form of heat (when tuned properly). It can run circles around forced air (referring to gas furnaces there, not to be confused with hydro air), less then stellar hot water systems and for surely electric strip heat
There is absolutely no possible way in a million years that strip heat would have been used. Not in 1973, not in 1993, and NOT NOW.
Don't they use WSHP's for cooling? and I guess the Co Gen is keeping the loop temp up for the WSHP's. Or maybe it's all different then I've heard?
