Results 1 to 13 of 18
    Sep 2012
    North Wales, PA
    RunCap Bandit makes a pass through Southern PA
    The Bandit did a little better with the electrical tape in this Rheem heat pump but the cap shows signs of rubbing against the 24V terminals on the contactor. I hope I don't meet the person who did this.
    Oct 2011
    between here and over there
    I like how he taped up the terminals on the cap to make sure they don't touch the case of the unit.. but leave it open to touch the side of the contactor and possibly short the 24v to ground.. is the other half of the body of that contactor missing?
    Aug 2008
    Las Vegas NV
    The cap looks like it woulda fit right back in the hole.
    Tallahassee, FL
    Nah its prolly too big a hole see this a lot on rheems.
    Mar 2009
    Mid-Mo
    Ya. That pipe strap is sooooo expensive.
    Jan 2013
    Henry county,ky
    Don't forget the cost of the screws to install the pipe strap. Not mention the 10 minutes of labor involved.
    " dirty filter??!!! Buts its only 2 years old" You never learn everything you need to know is this industry
    NE wisconsin
    Looks pretty close to the high voltage terminal too.
    Jan 2013
    Lack of care or quality gives us all a bad name make people think any one can do the job
    Jun 2011
    Detroit vicinity, Michigan
    Obviously he forgot to leave it in the anti-short cardboard box it came in. That's how they do it in the Detroit.
    Jun 2009
    northern Ohio
    You probably did meet the person who did this...it's the same person your going to make the bill out to.
    Nov 2011
    St. Louis
    How does everyone feel about a piece of cork tape adhering the cap to the cabinet?
    Jun 2011
    It's a high voltage device and should get the respect of one, secured properly with a metal strap or similar device. Also, when you install that cap improperly you lose the U.L. rating, there a reason every single one is secured that way, and who's gonna be the next guy to open the cabinet? I'd be pissed.
    Jun 2012
    I prefer to safely secure components in electrical like that with expanding foam.
Tags for this Thread
