Results 14 to 26 of 34
Thread: Testing for noncondensables
02-24-2013, 10:28 AM #14
Professional Member*
- Jul 2006
- Virginia
- 3,714
02-24-2013, 12:15 PM #15
You can run the test from the LL service port, no problem, even with the LL service valve wide open. Look for a SC reading on the static system with fan running of over 2°. You'll know when the liquid in the coil is at ambient temp when your temperature reading has stabilized. Any reading less than 2° SC could possibly be only instrument error, so don't scream noncondensables if your SC reading is above 0° but less than 2°. FWIW, if noncondensables are bad enough to cause noticable performance issues, then you'd really be looking for a static SC reading much higher than 2°. Convert your saturated temps to pressures, and do the math yourself. A 5 or 10 psi noncondensable partial pressure won't typically cause noticable symptoms. It would be best to get them out anyway, even at low amounts, but don't expect that in and of itself to eliminate the problems that you're trying to diagnose. HTH.
I've run this test many times. It works.
02-25-2013, 08:54 AM #16
Thanks medic, that's exactly what I was looking for. I figured there had to be a way.
catman-speaking from experience? Based on the specific details you listed...A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
02-25-2013, 09:40 AM #17
02-25-2013, 10:15 AM #18
Hey medic - this reminds me of the system you were helping me on this summer.
It was a txv indoors with a longish lineset all horizontal that would flash in liquid line close to indoor unit.
I was sure I had a liquid restriction but it ended up being noncondensibles and the txv had no liquid seal.
With the entire charge pumped into condensor it was about 25 psi partial or 10deg over ambiehnt.
I'm not sure how much static subcooling it would have shown with the long lines and all. Interesting.
02-25-2013, 12:51 PM #19
02-25-2013, 01:34 PM #20
It was called VACUUM back in my day, if you have P/T not measure accurate ,recover refrigerant, vacuum, check with micrometer and re-charge, NO more non-condensables
"Everyday above ground, is a good day".
"But everyday that you have made a difference in someones life, may insure you stay above ground a little longer".<aircooled>
02-25-2013, 03:24 PM #21A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
02-25-2013, 04:42 PM #22
- Feb 2013
- New Jersey before and after Texas
- 51
Pay at the pump
02-25-2013, 04:44 PM #23
- Feb 2013
- 51
02-25-2013, 06:03 PM #24
How much oil do you really get out with a pump like that anyway. I'm assuming you cut the suction line and try to snake a tube in their? Never tried it but seems impossible on a scroll.
02-25-2013, 06:19 PM #25
- Feb 2013
- 51
02-25-2013, 06:39 PM #26
- Feb 2013
- 51
There is no such thing as extra virgin olive oil either... Interesting fact picked up from Italy.. Anyways, I would think it can pump four to seven ounces per stroke. I would feed the tube through the "skinny" line...
