Results 1 to 13 of 23
    Feb 2013
    rheem over temp limit error
    I have a rheem 90 plus series model number rgfd07emcks over temp limit error 33, right when the unit starts up cold it flashes code 33 over temp limit. I have used the volt meter took it all the way to the board. I could not find an open anywhere. I then jumpered the whole circuit at the board still got the same code. I figured it was a bad logic board so I changed out the board however still have the same error code. '
    Does anyone have any ideas
    Northeast, PA
    Are you the service tech, or the homeowner??????
    Dec 2008
    Buffalo NY
    Could be a lot of things. Is is a two pipe setup?
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Atlanta GA area
    Hmmm... RGFD... that is a MOD furnace (modulating). You really need to get a RHEEM guy out there... this furnace is unique... not an average unit and not easy to service unless one understands the unit.
    Furnaces are not DIY products... folks can cause a lot of damage and potentially create an unsafe condition if they try.
    GA-HVAC-Tech
    Dec 2008
    Buffalo NY
    Quote Originally Posted by stuff350 View Post
    Jumping things out on that board can screw the board up.
    Northeast, PA
    Quote Originally Posted by ga-hvac-tech View Post
    Thats what I was getting at, just from the post theres a possible drowning situation there.
    Atlanta GA area
    Quote Originally Posted by TriWorksInc View Post
    Yeah... If this guy is trying to DIY this furnace problem... he may spend a LOT more $$$ on his learning curve than calling a Rheem person and paying them to do the work properly... not to mention all the time, aggravation, and possibly nights on the couch 'cause mama is cold and irritated...
    GA-HVAC-Tech
    Feb 2013
    Sorry, I was not specific when I said jumped it at the board, I'm an OSU -it student in the HVAC program and am working on this project for extra credit. I jumped it from the back side of the plug before it goes into the board .
    Northeast, PA
    What I do is work with the tech manual right in front if me? There are too many mistakes that can be made with electrical troubleshooting and you need to follow protocol while troubleshooting and don't use jumpers in the wrong places, good luck.
    Dec 2008
    Buffalo NY
    Check for three things:
    Faulty limit control
    Insufficient combustion air
    Unstable flame pattern
    Feb 2013
    The burner don't fire off at all right away it gives off that high limit error
    Atlanta GA area
    Might clear the board... then start over... sometimes codes get 'stuck' in a board... power off and count to 10... then power back on.
    If you are in school and doing a project... I would go through the entire troubleshooting chart in the IOM manual (I assume they gave you the manual)... sooner or later you will find something of interest.
    Then when you KNOW what was related and what was not... you can explain the WHY's of what was wrong and how to fix it.
    Knowing the WHY's is the key to this industry... otherwise... one becomes a parts changing hack.
    GA-HVAC-Tech
    Feb 2013
    I like that point you made with the parts changing hack, there isn't much of a manual that came with the unit and yes I did clear the board even changed the board.
