Results 14 to 19 of 19
    Dec 2001
    Harnett County, NC
    I just bought a cheap CPS leak detector. It has been great for 410a found every leak I searched for so far, not so much for 22.
    Jan 2010
    Quote Originally Posted by Snapperhead View Post
    10 pounds in a resi unit ?? yea ok
    5 tons often exceed 10 lbs, Rheem 5 ton heat pump 17lbs
    4 ton rheem tax credit 16 seer / 18 seer coil was 14 lbs
    French Settlement, Louisiana, United States
    Went on a micro channel luxaire that data plate showed 3lbs 4oz. Homeowner said she had just paid for 9lbs from company x. So I showed her on the unit where it stated the amount
    Apr 2010
    NYC
    When it's Flat don't you guys put nitrogen,, Give it a rapid blast than use ear. It' also increases the pin whole. Seen it done many times.
    Customer is alWays opposite of Left
    Quote Originally Posted by zartangreen View Post
    Bad thing was mine wasn't flat. It was icing up. Only about a pound low. Checked with a leak detector and found leak in evaporator coil. Replaced under warranty and homeowner paid labor. Now she will not call company x again due to my honesty.
    Apr 2010
    NYC
    Honesty always pays off in one form or the other.
    There r Customers out there who think A/C need to be tapped off every Pre-summer. Sometimes the Hacks have them Trained as a Yearly ATM withdrawl.
