Results 1 to 13 of 25
    Jan 2013
    Frederick, MD
    Restriction from hell
    I love a good challenge and the chance to learn something new. But this one was ridiculous.
    With the correct charge weighed in the suction would pull into a vacuum after about 30 seconds and the head pressure would run about 270 psi.
    Now this is a new house. First time the A/C has been run.
    After over charging the system enough to get some suction pressure returning to the unit I was able to check the line temperatures inside and out. Only the usual 2-3 degree temperature difference. By this time the pressures were 650/125. So I did not let it run very long like that. Replaced the TXV at the indoor coil. While it was apart I blew through the line set with plenty of nitrogen. no problems. Put it back together....Same problem.... Next I ran a temporary new liquid line down the attic access hole and out a window to the outdoor unit....Same thing... By this time I'm getting pretty frustrated. Finally I pulled the evaporator and brought it outside. Sat it on top of the condenser and piped it in. Finally it worked. Now came the hard part. Replacing a 90 foot line set in a fully finished $500,000 house.
    After all day the new line set fixed the problem. How ever I was never able to locate a problem with the line set I pulled out.
    Just a side note. The line set I pulled out was aluminum.
    South Carolina
    aluminum?????????????????????????
    It is what it is unless I say differently !!!!
    Jan 2013
    Frederick, MD
    Yes Aluminum. My company gave it try. It was in an effort to cut cost. They have since changed their minds and we no longer use it.
    South Carolina
    sorry never heard of it in residential work
    Jan 2013
    Frederick, MD
    Jul 2009
    Columbia, MD
    someone forgot to take the plug out the lineset, or the coil
    Quote Originally Posted by Frederick_Tech View Post
    Probably cost them >100x what they were trying to save on that job, lol.
    Jan 2010
    Who sells aluminum line sets ?
    Was there a kink in it somewhere, I can see where aluminum would be easy to kink.
    Athens, Ohio
    How do you connect and aluminum line set? Can you braze it?
    May 2011
    Western, KY
    Also, I would be interested in the method used to seal the connections at the coils(what material was the aluminum joined to at coils) and the splice since it was 90'.
    Mar 2009
    Mid-Mo
    Did it have a copper coated stubs on the ends? Not too uncommon to have copper coated steel on bigger stuff....
    Apr 2013
    Was the replacement line set the same size? Also was the length and lift of the line set within specifications? I'm not seeing how the line set was a problem no matter the material if it had good flow through it with nitrogen. That's why I'm wondering if any sizing or routing was done differently with the line set. 90 feet is a good haul and units like trane 20i's are real funny about that length and lift
