Results 14 to 21 of 21
    May 2008
    Missouri
    Is this a two line system (return line included?).
    Southeastern Pa
    Looking at it will tell him if there's a problem with the lines, such as a kink, a spot crush, or some other damage.
    Occam's razor is the principle that the simplest explanation is usually the correct one. The OP just moved his tank.
    What is the likelihood that moving the tank has caused a clog in the line?
    May 2008
    Missouri
    Good guess, there probably is a lot of sludge and rust in the bottom of that tank that was loosened when you moved it.
    Jan 2011
    Boston, MA
    Quote Originally Posted by paulmars View Post
    Will looking at it clear it out?
    wow..
    Southeastern Pa
    Quote Originally Posted by wahoo View Post
    While that could happen, I'm thinking that is not the likely situation. Older tanks that have a dip tube several inches above the bottom have developed a sedimentary layer that compacts and becomes pretty stable over time. You would have to be pretty careless in the moving, repositioning, and installation to get that stuff up into the dip tube. It is much more likely that this would happen if an unskilled guy installed a NEW dip tube, and stuck it INTO the sediment. A good contractor would flush the tank, properly install a new tube and lineset, and install the tiger as mentioned above. Since this may not be a contractor-supervised job, I'm thinking the best reason is a kink or crush somewhere, and a clogged strainer is the second possibility.
    Of course, in a cyber-diagnostic situation, we are all guessing. At a minimum, you can eliminate the line by exposing the connections at each end and see if the line is clear.
    I DO recommend a good contractor be used at this point, to cover all the bases, "live and in person."
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Sep 2009
    I cant get any advice on which tigerloop to use. I cant afford a contractor.
    May 2008
    Missouri
    We are not allowed to assist with DIY repairs. Against site rules.
    Oct 2006
    The Beach
    Check those lines. Either a leak or a kink. Do you have the lines the right distance down in the tank? That two stage pump might be the answer. (If yours system does not have one. Your pump filter might be stopped up. Has your oil filter been replaced. How is your nozzle? You might have to call an oil burner man. The oil we are getting now is not very clean. Have to change the oil filters a lot more offen than we used to. Sludge is a real problem now. In your tank, lines, in your pump filter and line filter.
    Blue Fox
