Thread: Iced up Coil.
    Feb 2011
    Philadelphia PA
    Iced up Coil.
    I went to a two door freezer and found the coil iced up. Forced the unit on defrost and realized that the relay that energizes the electric heaters was not closing the contacts. Replaced the relay and checked the unit defrost and refrigeration mode, all ok. Is there anything else I shoild have checked? Don't feel confident I solved the problem
    Oct 2011
    Chicagoland Area
    Model and serial #? How did you determine the relay was bad?
    Feb 2011
    Philadelphia PA
    Yes the relay was bad. Mo is GDM-49F
    Oct 2011
    Chicagoland Area
    Relay on the Grasslin timer?
    Dec 2012
    Spokane, Washington
    If you see Kay...tell her that GDM freezer is iced up again!
    A smooth sea has never made a worthy mariner
    English proverb
