    May 2009
    Hmm Heat pump thermostat
    I have a Rheem Rpnl-030jaz heat pump with a Rheem RHPL-HM3621JA vari speed air handler. I want to get a thermostat for this that I can check house temps when I am away. I was looking at Honeywell redline stuff. If I am right it looks to me that I would need a HZ432 a True zone and a wireless t-stat and a wireless adapter set-up. Does this sound right? Is there another brand that does the same thing for a better value?
    Do you need zoning? Otherwise a Focus Pro WiFi or Vision Pro WiFi don't need the gateway.
    Aug 2008
    Booneville, Mississippi, United States
    Ecobee has a nice stat! Nest does also!
    May 2009
    Arrow dehumidify
    I want to make use of the dehumidify or "odd" terminal in the air handler. Will that work with the Focus Pro WiFi or Vision Pro WiFi? No I am not needing to zone I have heat pump 1 stage cool 2 stage heat- heat pump and electric heat.
