    Feb 2013
    Duct Insulation wrap
    What is the best material to use on the metal supply box to insulate. Some say foil backed Polyisocyanurate board and some say foil backed fiberglass roll. Not sure which way to go.
    Feb 2013
    Additional infractions may result in loss of posting privileges.
    jbroberts38
    south louisiana
    duct board or duct wrap.
    foam products are not acca approved.
    newer installs usually have insulated supply boxes.
    best of luck
    Apr 2010
    NC Sandhills
    Ductwrap ( fiberglass roll with foil backing) is king around here.
