Results 14 to 26 of 33
    East of big city prices.
    If you remove the panel there is a red and green led I believe , see what they are doing. Then check that 24 VDC power supply.
    Feb 2013
    Vancouver, BC
    yes, there is. they are both off
    Sep 2003
    You may have a bad drive.
    Local 449?
    Feb 2013
    Green Valley AZ
    I'm assuming it's a 480 or 208 primary. If that is present at the drives disconnect, are you making sure it is also getting out to the load side of the disconnect to the drive itself. Sometimes those disconects don't line up well with the handle on the outside of the drive. Those baby's have always lit up if they got power.
    Feb 2013
    Vancouver, BC
    Ok, so...
    Service tech from ABB came over today and declared 3 drives FUBAR on electronic level.
    He took one of the drives with him to run it through some tests and determine the cause.
    Now the cause is obviously somehow related to ongoing construction, but since those drives were wired by previous contractor, my boss ordered to withdraw the drive from the lab, reinstall it in place and let base building deal with it. (Kinda not our wires - not our problem).
    Luckily for me, I have checked the drives before rewiring them. Otherwise would have been my fault.
    Hopefully I will be able to find out what exactly have caused it. Things get pretty interesting...
  6. Likes throrope liked this post
  7. #19
    Sep 2003
    I doubt you will be able to ever determine the cause of failure. I had the same issue with an ACH550 last summer. Power in and no power out. No LED lights.
    Local 449?
  8. #20
    Mar 2012
    Southern CA
    I know that this particular case has been resolved, but I've also seen a faulty under-voltage relay keep the drive off
  9. #21
    Feb 2013
    Vancouver, BC
    Faulty under-voltage relay? Is it possible to readjust at what voltage it drops out?
  10. #22
    Feb 2013
    Vancouver, BC
    Well actually I didn't see it inside the drive. And voltage seems to be within the range (567-570V on 575V system)
  11. #23
    Mar 2012
    Southern CA
    Quote Originally Posted by ddcbacnet View Post
    In my case, the set-point (not even sure if it was adjustable, might have been) wasn't an issue. if i remember correctly, the relay was a NO contact in the control circuit portion of the drive. The coil went bad and it kept the drive off. I switched the connection to the NC terminal and presto it came to life (temp. fix of course)
  12. #24
    Dec 2012
    Lowell,MA
    do you have o/m manuals? has pretty good troubleshooting chart at back of book or can call abb 800-help-365
  13. #25
    Feb 2013
    Vancouver, BC
    Spoke to building engineer today. Speed drives are dead as a doornail and not subject to repair. It was caused by internal electronic failure within one of the components. Same component in all three drives. They did not mention which one.
    They say they will never turn them off ever again
    Lesson to learn: ALWAYS commission devices and systems you are about to upgrade.
  14. #26
    Dec 2011
    Fort Worth, TX
    I have seen where someone accidentally hits a low voltage wire on a high voltage something (24volt wire hits a 277 volt leg) and instantly everything on that 24 volt circuit (safety or control) will never work again. Sometimes it is visible with small black arcing sports and sometimes not.
