Thread: Trane/AM heat pump issues
02-16-2013, 10:23 AM #1
- Oct 2011
- TX
- 82
Hey guys,
Not used to these new HVAC unit as I am a refrigeration guy. I just installed 2 new units in my parents house. American standard 4a6h6036c1000a paired with the tam7. I am having a problem with the downstairs unit going off on an error code 10, y2 with out Y1. I have checked all wiring and its identical to the other unit that has been running fine. I did have to install the non communicating wiring harness on both units. Not sure what to do at this point, thinking about switching the t stats to see if that is the problem. Brand new t stats though. Let me know y'all's thoughts. Thanks in advance!!
02-16-2013, 10:40 AM #2
- Jan 2012
- tennessee
- 18
in your literature that came with the unit what does error code 10 say the problems could be?
02-16-2013, 01:23 PM #3
- Oct 2011
- TX
- 82
All it says is Y2 without Y1. Mis-wire. I switched y1 with Y2 and it seems to run fine now. Very weird, the other unit is wired the exact same way and no issues. I even switched both tstats to see if the t stat was bad, same result. Overall I'm pretty impressed with these variable speed motors.
