Results 1 to 13 of 16
Thread: trane aluminum i.d. coils
02-16-2013, 09:35 AM #1
- Feb 2013
- north georiga
- 127
my boss just went to trane recently and i am wondering how long has trane been using the aluminum i.d coil and how have they been holding up
02-16-2013, 09:59 AM #2
They have been using them for a few years.. I have found a few of them leaking after install, due to the zip ties they use on the coil to secure the cap tubes of the TXV, they rubs a hole in the U bend. a couple were found to be leaking where the copper meets the aluminum. but out of the hundreds we installed in the past few years only a handful have been found leaking so far....
02-16-2013, 11:09 AM #3
AS/Trane started the transition to all aluminum indoor coils in 2006.
I've only found one leaking so far, at one of the crossover tube connections to the coil, but we don't have thousands of them out there like bigger shops do.If more government is the answer, then it's a really stupid question.
02-16-2013, 11:54 AM #4
My company has installed a lot of the Trane aluminum coils. I first started seeing them in the Hyperion AHU's then they started sending them as replacement for older leaking coils.
I have found a 2 or 3 that have leaked but mainly due to the copper and aluminum rubbing.
Overall, I think the all aluminum coil is 100% better than all copper.
02-16-2013, 12:21 PM #5
Agree, they are a better coil. I would say 70% of my summer work are replacing coils and such. I work for a large company, is not unusual to have 2 coils and some no cools per day. Only have replaced like I said a handful of them mainly because they are running on a harder metal. If you take a few mindsto prep them and move parts away from each other carefully and cut the zip tie from the cap tubes you should be okay. Just a habit I got into when installing.
sent from my Note II®
02-16-2013, 02:46 PM #6
- Oct 2012
- Sacramento,ca
- 179
02-16-2013, 03:01 PM #7
and why wouldn't you be able to repair the aluminum coil?
02-16-2013, 03:03 PM #8
All aluminum coils are immune to the formicary and galvanic corrosion that are the 2 most common causes of leaks in residential evaporator coils that have been a plague on the industry for a couple of decades.
Leaks due to formicary corrosion are typically found in the fin area of the coil, and are essentially not repairable. Often it is many micro leaks, but even if it is just one bigger leak, repair would involve removing fins to access the leak, and with 3 or 4 pass coils, would not even be accessible then.
Leaks from galvanic corrosion at the tube sheet are also difficult, if not impossible, to fix reliably.
In either case, just the handling of the coil during repairs can cause more leaks in other parts of the coil with weakened tubing.
Even if you get every leak, and get it all put back together, the repair would likely cost more than half of what just replacing it would cost, and the customer would be left with a coil that is highly likely to develop more leaks.
Back when coils used thicker tubing, and had fewer fins per inch, you had a better chance of successful repair, as the leaks were usually at soldered connections for the crossover or distributor tubes.
Now, with the thin tubing, that is also rifled, tight fin spacings, questionable quality recycled copper, etc., most leaks in residential evaporator coils are not reliably repairable.
There was a time when Carrier and GE used all aluminum indoor coils. Other than leaks caused by mechanical damage, I've never found one leaking in the coil itself, only at the mechanical fittings used to connect the refrigerant lines.If more government is the answer, then it's a really stupid question.
02-16-2013, 03:13 PM #9
- Oct 2012
- Sacramento,ca
- 179
Thanks. Makes sense. I guess i have been lucky because i have installed 100's of ADP coils on my installs and not had a problem yet. Not sure if there is a lot of difference between brands but all the leaks i see are in allstyle coils three to ten years old.
02-16-2013, 03:34 PM #10
02-16-2013, 05:34 PM #11
- Feb 2013
- north georiga
- 127
guessing from your stated location these are heat pumps, and another tech asked about repairing the leaks, have you had to repair them or are they still under warranty?
02-16-2013, 05:43 PM #12
we have replaced more aluminum case coils than aluminum heatpump coils. I live in Florida the area I live and work in is supplied with natural gas. there are some techs that have repaired aluminum coils but.. the cost of doing such work amounts to more than it is worth. you can get a new coil for almost the same price.
When it comes to more humid geographic locations I dont know what factors into why the coils fail. It would make sense to blame it on humidity and condensation on the coil.. I'm not an engineer or a scientist..®
02-16-2013, 05:58 PM #13
Professional Member*
- Sep 2005
- North GA
- 17,677
Was not aware of that... Will this be a total switch... or offered as an option?
The AlliedAir products I have been installing the last few years (part of Lennox); the coils are all ADP. Be interesting to see aluminum coils show up there.
Also; heard at the local Rheem shop that later in the year Rheem/Ruud will go to aluminum indoor coils... still the N configuration if I hear correctly.GA-HVAC-Tech
2 Chronicles 7:14
