Results 14 to 26 of 34
    Oct 2012
    Sacramento,ca
    Quote Originally Posted by hvacrmedic View Post
    The subject here is suction line filter driers. Suction line driers will typically have pressure taps on them. LL driers typically won't.
    As for your initial comment, there won't be a temperature drop across either a suction line drier or liquid line drier unless there is at least some liquid going into it, and a liquid/vapor mixture going out of it. If you have either gas-in-and-gas-out or liquid-in-and-liquid-out, then you get no temperature drop. In either of these two cases you'd typically need some means of measuring the pressure drop directly. Adding a pressure tap is the only practical way to do that in some cases, so don't hesitate to do that when you suspect a restriction and aren't seeing a temperature drop.
    You can have a significant restriction with no temperature drop across it so don't assume that there's no restriction just because there's no temperature drop. IOW, what you've always been told is wrong at face value. There's a lot more to be said, but you can search the forum for threads that cover this topic.
    Thanks for the insight this is why i come here to have clarity on the wrong things i have be taught. I must be buying some cheap suction filters because none of the ones at my local vendor have taps on them, i carry piercing valves for this though.
    Jul 2005
    Quote Originally Posted by Barrettservices View Post
    You should think about buying them elsewhere.
    Aug 2012
    What about over sizing the slfd, would that elliminate the need to change it out???
    It's not if your doing it right it's whether your doing the right thing that is important.
    Apr 2003
    Greenback, Tennessee
    We almost never install a suction line dryer but, we always replace/install a LLFD. We have had good results. I'm not arguing in favor of this policy. I'm just say'n that's what we do and, we have a good track record doing it.
    -Marty
    Virginia
    I try to treat customers units as if my very own , and if I had a burn out , I would want a big ol high acid suction filter there catching anything coming out of the indoor coil that might harm the new compressor.
    Jul 2009
    Columbia, MD
    I would install my suction line drier outside of the unit and wire it to stay in cooling. This way i didn't have to do handstands on trane units.
    Mar 2010
    Kent, WA.
    i wish more people on the commercial end would come back and remove the suction filter/dryer. i have a few accounts that i inherited and they have some that were installed in the 80's and 90's, units check out fine tho so im not removing till another failure.
    michigan
    Quote Originally Posted by hotrodrob View Post
    They may have felts in them, whats the harm?
    Apr 2003
    I did that on a Trane HP that had had several compressor failures and no suction dryers were installed. Have not been back since.
    -Marty
    Apr 2003
    Agreed but most customers in our market would not pay for the cost involved. Your market may be different?
    -Marty
    Virginia
    Quote Originally Posted by m singer View Post
    you know what , all you can do is offer them good advice , after that , the balls in their court , and thats about all you can do buddy
    Everyone here sees it all of the time .... most of the time we walk away shaking our heads
    Oh well , i think some smart fella once named it "job security"
    Jun 2007
    Greenwood Indiana (Indianapolis)
    acid away works. There is different types depending on what refrigerant you have. I am a big believer in suction line dryers. I also am a big believer that they can stay in if the pressure difference is minimal.
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    Feb 2012
    Moscow
    But if the pressure drop is up to 30 psig due to long piping I'd rather put largher compressor in first after replacing the burning out compressor.
