Results 1 to 2 of 2
Thread: Close enough?
    Sep 2006
    Burnaby, BC
    Close enough?
    It's just return air, right?
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
    Jan 2013
    Henry county,ky
    Well at least it wasn't completely closed off. I will tell you one better, the company i used to work for set a 20 ton rtu. Tech went out to start it and called saying it was blowing smoke everywhere. The idiots forgot to remove the bottom panel before it was set on the curb. The burn off had no place to go but out every nook and crack in the unit.
