Results 14 to 24 of 24
Thread: Kablooey!!
    Delta BC Canada
    Hope you still have your ebrows there Karl. How are things these days at the big E
    Chicago, IL
    Fun fun fun!
    Also, I see I'm not the only one that has "field engineered" those old Johnson Controls G60 combination gas valve/ignition controls to use use a modern spark ignition module.
    It's funny how every time a manufacturer tries to combine a gas valve and an ignition control (which are both pretty reliable on their own) it immediately turns the result into a huge piece of garbage like the g60 and smartvalve
    Rochester, MN
    Dang, I jumped a little!
    Jun 2002
    south jersey
    Holy crap, that sucks. Same thing happened to me on one of my rare resi call. Customer hears loud bang when unit runs. Find furnace in basement, cabinet side 12" from block wall blocked on other 3 sides. Without thinking I try to start it and get pilot and hear gas open but no flame. Go to reach around to disconnect and boom. There goes my arm hair. You could still smell the stink I left in her basement when I s**t my pants.
    I wish I had video of the "Belching Dragon" I worked on back in the 90's.
    Lennox whisper heat with a failed proving switch for the damper, that the homeowner had tried to fix himself.
    Somehow he managed to get the wires screwed around to the point that the gas valve would open at the same time the damper started to open.
    Once the damper opened far enough to make its proving switch, the ignitor would start sparking.
    The furnace was an upflow in a closet, and I was bent over watching the startup sequence, and failed to notice that the gas valve had gotten energized...
    Use your imagination from there.
    Lets just say that my first stop after that call was my barber.
    Nov 2011
    St. Louis
    Damn dudes...what part of "customer reports loud bang upon start up" do you not understand?
    Sep 2006
    Burnaby, BC
    Quote Originally Posted by DPinst View Post
    All my hair is intact. I'll call you soon to talk, DP
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
    Nov 2009
    Central Virginia
    Wow. Scary stuff. Thanks for posting this!
    May 2013
    near knoxville tenessee
    when i was a newbie and didnt have the spidy senses i had my eyebrows burnt off by delayed ignition on a hanging heater. that was 20 years ago and it hasnt happened again! You learn delayed ignition fast..
    Okieville
    Love the very end... "OOH it's gunna be a good one!!'.............BOOM!!!!!
    Quoted by "bmathews"
    "Just call somebody out. Nobody on here can fix it from over the computer."
    Sep 2006
    Burnaby, BC
    Couldn't talk about it before, but I have left to go work for myself.
    Give me a call sometime. It's been a while.
    Pick two
