Results 1 to 13 of 24
Thread: Kablooey!!
    Sep 2006
    Burnaby, BC
    Kablooey!!
    Found a Carrier 48KHA with the usual panel hanging by one screw. Caught some nice footage of it as well.
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
    Jul 2009
    Columbia, MD
    wtf!!!
    Jul 2009
    Columbia, MD
    Just watched part 3.
    What a great spot for a hole to be
    Jan 2013
    Henry county,ky
    Nov 2009
    Tennessee
    I smell burned hair...
    Jan 2013
    Henry county,ky
    And a change of under pants.
    Sep 2006
    Burnaby, BC
    I assure you my underpants are fine and I still have all my hair.
    I held the phone at arms length.
    Pick two
    Jan 2013
    Henry county,ky
    Well mine wouldn't be once that first flash happened.
    Rochester NY
    Great post!
    Jul 2005
    Southern California
    Cool thanks for sharing that!
    Knowledge is knowing that a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad.
    Jun 2012
    That was the very unpopular anti arachnid option.
    Fun fun fun!
    Also, I see I'm not the only one that has "field engineered" those old Johnson Controls G60 combination gas valve/ignition controls to use use a modern spark ignition module.
    So Cal, Maui, & Kauai
    Fun fun fun!
    We used to install Y86 kits on those units when they were cheap..
