Results 1 to 2 of 2
Thread: Wet duct
    Feb 2012
    Wet duct
    Hopefully this doesn't tread too far toward DIY territory, but
    I've got a little problem with a cold-air intake that someone
    might have some insight into. You guys must deal with
    fresh-air inlet ducts in some fashion once in a while...
    This is the inlet to an HRV, and is a piece of PVC pipe
    that comes in through a sealed wall penetration. It's
    PVC instead of metal to avoid thermal bridging to outside,
    but it's still passing cold air so the whole pipe is
    naturally going to get a little chilly. It connects
    immediately to a piece of insulated 6" flex that runs
    right down into the HRV inlet. In the original setup,
    the outer jacket + fiberglass of the flex was snugged
    up around the PVC pipe tight to the wall, to try and not
    expose any of the cold bits. Last night I discovered
    that air circulation around that area had nonetheless
    caused condensation to form in the end of the fiberglass
    and start soaking down into the flex duct *and* into
    the wood of the wall that the pipe passes through.
    When y'all do a fresh-air duct penetration for cold
    climates, how do you prevent condensation problems
    on the inside??
    tnx
    _H*
    SW FL
    Definitely DIY, but I doubt that it 'treads on the trades' here.
    Haven't tried it, but Spray Foam certainly seems like it would be a good insulator AND sealant.
    Designer Dan
