Results 1 to 13 of 13
Thread: Rusted Evaporators
    Feb 2013
    Rusted Evaporators
    The four HVAC units pictured are 9.5 year old Trane TUE100A948L with rusted evaporators. I have been told the entire furnace needs to be replaced. I am asking, is it typical to last only 9.5 years; I did have a twice-yearly Preventive Maintenance program for the entire 9.5 years; should I get another Brand? The original company is out of business and the HVAC Co that provided Preventive Maintenance reps Honeywell.
    The TRANE Condensers are fine, but use R22 which the HVAC Co told me is no longer available. A metering device for R22 vs R410A is available, but was told it’s not worth the hassle. It was replaced by R410A refrigerant, how long will R410A be available? Should I try to use the HVACs until they break down, I live in Texas?
    All advice/comments will be appreciated.
    Is it leaking r22 (freon)?
    They all rust.
    Is it leaking refrigerant?
    R22 is still available.
    The rust is only on the tube sheet. If the systems aren't leaking. Keep using them. That rust is not a reason to change out a system.
    If they are not leaking refrigerant, don't worry about it, there isn't anything unusual about the amount of rust on those coils.
    Newer Trane coils, as well as some other brands, are all aluminum, so there will be no issues with rust if/when you replace them.
    Feb 2013
    Thanks for your responses, you taught me what I needed to know.
    FYI: The units are Not leaking.
    Aug 2001
    Pavilion, NY
    Did the contractor tell you that it should be replaced because of the presence of the rust?
    North Dakota
    it sounds like they are out for a quick buck better find a new hvac guy
    May 2009
    Cumming, GA
    Change contractors.
    May 2008
    Missouri
    I agree with most others......change contractors and don't let these guys near your home!!!
    Feb 2013
    Rusted Evaporators
    Regarding changing contractors:
    I don't want to trash a 9 year business relationship (it's a large employer), because one person over zealously tried to scare me into a sell (the sell part didn't work, but the scare did).
    I spoke with the Service Manager after I received your responses. Someone may have suggested the technicians look for new business on their maintenance appointments or this tech was trying to bump his commissions; but I don't want him to lose his job.
    I am not scared anymore because you all helped out with your comments...Thank you, thank you very much.
    In answer to kangaroogod: Yes.
    May 2008
    Missouri
    Our "caution" is simply that you are involved with a firm who puts a very high priority on sales, and not necessarily on service. Resulting in undertrained techs "selling" simply because they either make larger commissions, or ignorance. Ethics must sooner or later become a factor in deciding whether to find someone else to take care of your system. Ethics are practiced within the company on a daily basis. Rust on the end plates of an A coil is VERY common and should NEVER be a reason for system or coil replacement. If this tech is coming into a customer's home and does not know this, then I'd be concerned. You were right to follow up with the service manager, however the manager I'm sure was somehow involved in this from the beginning also. Either by default, or direction. Be careful and don't hesitate to post if need further assistance!!
    North Dakota
    your hesitence to have him fired is understandable though what about the old lady on his next call who gets taken for her fixed income check by way of scare tactics and dosent know to check other avenues or get second opinions? as it is likely the whole company doing the nasty not just one rouge tech ! watch your step , your a long standing customer with a service contract and they didnt mind taking you for a ride . a whole system over rusted coil sheets, wow wish I had your tollerence !?!?
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
