Results 1 to 13 of 27
    Feb 2013
    Control board repairs or work around
    I am a tech that works on residential appliances and on occasion will take on commercial equipment for friends or nuns that call me with a problem. (seems I'm the only one that will help out a nun around here or the only one they call either way EXTREMELY Ironic). I picked up an ice machine that was flooded in the last hurricane we had down here and am either looking to use it at the house or sell it once I get it working.
    Does anyone have any experiences with having control boards repaired? I'm in search of a control for a Manitowoc QYO454A and they are expensive as as giraffe nu*s are high. The unit is about 10 years old and is in good shape other than the harvest cycle initiates right after the time out ends. Disconnecting the water probe does nothing.
    I've found a site that claims that they can repair them but I'm leery to send the board to them and they say it can't be repaired and lose my shot of getting it fixed in the process. Anyone have a solution, workaround, or advise on this? I'm having a hard time thinking of trashing the machine because of a control board when the sealed system is in working order. It will work make ice on it's first cycle, then errors on the next.
    Feb 2007
    Fremont, Indiana
    Quote Originally Posted by wobiii View Post
    I would troubleshoot further (harder) before condemning the board jmo
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Feb 2013
    Thanks, but how? Service manual says to run with the ice probe hooked up, then with it off to test it looking for different results. Same results both times. I have read that these boards are pretty damn tough but this one went under water and still runs the machine mostly.
    steeler nation
    "they are expensive as as giraffe nu*s are high"
    cant help you but love the quote
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    Feb 2013
    Quote Originally Posted by viceman View Post
    Thanks Vice. Also let me offer you the qote varation of "high as giraffe nut*" as used most often when dealing with a salesman.
    Western New York
    I have repaired a number of ice machine boards. If the #3 relay (for the harvest solenoid) on the board is defective that would cause your problem.
    Experience is what you have an hour after you need it.
    Feb 2013
    Thank you Baub, I probably have one laying around here so if I can find the right one I'll give it a try. Thanks.
    Jul 2012
    Western KY
    If you got a relay and wanna try nothing to lose but time. Spend enough time trying to fix it and and you could end up loosing money over just replacing it. That's why service companies rarely mess with it.
    Feb 2013
    Thanks and understand the advise but it's a garage project now in my garage so it'll just be drinking beer trying to fix a board learning experience time anyway. I would never do this for a customer because I couldn't guarantee it and the liability that it brings. Best price I could find on a board was 600, so that's a good bit of messing around time.
    Southeastern Pa
    First, I would make sure that the ice probe is nice and clean.
    If the problem is still there then I would probably substitute that number 3 relay mentioned above. Microrelays are not designed to be submerged so you might want to pull the covers off of each one to make sure they're clean and dry inside. You can use contact cleaner to clean out the inside
    Western New York
    Maybe this will help...
    Feb 2013
    Ok have all relays replaced, not really sure of the condition of every one of them but had enough laying around to replace them. Had one that was rusted to pieced on the inside. So I just reinstalled the board and it's still in its first cycle. Will let you all know in a few what happens. Regardless, thank everyone of you for the help so far.
    Walt
    Feb 2013
    No change, same problem with the red harvest light even with the ice probe unplugged.
    No change at all, same problem. Even with the ice probe disconnected.
