Results 1 to 12 of 12
    Jan 2013
    Missouri
    Heil Rectifier How to test, and its function?
    Heil Electric Furnace
    M#FSA2X2411A
    S#A061872407
    Service call no heat.
    We follow the power and turn it on and it works! So a lose connection somewhere.
    While we were following the power we came across a rectifier and we really had no idea what it's doing there?
    The wiring diagram only showed low voltage going through the rectifier even though the high voltage was going through it.
    We talked to a few people. One suggested the board may be using DC volts hence the use of the rectifier. Another said they are just a extra piece that you possibly really don't need. Yet another said just buy a new one if u have any problems they are only $$$.
    So replacing it is a simple solution BUT
    How would one go about testing it?
    What exactly is it for/Why is it there?
    Jun 2006
    Richmond, VA
    :0 You sure this was a "service call"
    It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!
    Jan 2013
    Missouri
    My bad, diagnostic. Call it what you will. The heat was not working when we showed up and it was when we left.
    So you have no clue on the rectifier??
    Jul 2009
    Columbia, MD
    I'm not 100% on your unit.
    I have seen 2 scenarios
    1. board will send 24vac to relay which rectifies to 22vdc and energizes relay.
    2. board sends 22vdc to a dc coil relay.
    I don't know why they do it. Maybe because it can be smaller? who knows.
    Jun 2006
    Richmond, VA
    Quote Originally Posted by gravity View Post
    It's just an apartment cheapo electric airhandler....it doesn't have a "rectifier" anybody on a "service call" that can't figure that out shouldn't be on a service call.
    Jan 2005
    Columbia, Mo GO, TIGERS
    what would you have him do then, Einsteinshvac-----up and QUIT?
    well, yeah, I know, if it is good enough for the Pope....
    Somebody quick call ICP, they got an unfortunate misprint right on the Heil wiring diagram showing a "REC" which Legend claims stands for "Rectifier", which gets 24VAC & sends 22VDC to the control coil of the relay for switching on the heat strips. But we know better.
    Now as far as troubleshooting I would invoke the old saw that if a component is receiving the proper input and yet fails to provide the proper output...you know the rest.
    Or else you should not be walking in the park, or barefoot on the sand, or on hot coals, or reproduce. Just to be on the safe side. Oh! Or fix furnaces. Almost forgot. Yep, definitely not. Positively negative.
    Pg. 324: "the powers of financial capitalism had another far-reaching aim, nothing less than to create a world system of financial control in private hands able to dominate the political system of each country and the economy of the world as a whole. This system was to be controlled in a feudalist fashion by the central banks of the world acting in concert, by secret agreements arrived at in frequent private meetings and conferences."
    Tragedy & Hope, by Carroll Quigley
    that rectifier is a big turd, all it does is provide dc voltage to the relay coil, most all I've seen were in the melting stage.
    Lancaster PA
    Quote Originally Posted by beshvac View Post
    And it wouldn't be the only cheap air handler that had a rectifier in it. Carrier did that for quite a while.
    Jun 2006
    Richmond, VA
    My mistake
    Jan 2013
    Missouri
    Final conclusion:
    Low voltage AC being changed to DC for the board.
    High voltage on a relay in the same part.
    Thank you all have a great day!
    the ones I've run across will unplug from the relay.
    Jun 2001
    Oklahoma City
    Quote Originally Posted by dandyme View Post
    +1, I have seen them used in Goodman air handlers.
