Results 1 to 13 of 28
Thread: Duct leakage questions
02-13-2013, 02:04 PM #1
- Nov 2012
- Worcester, MA
- 15
Do you guys duct seal and/or tape the seams of the snap lock on ductwork?
02-14-2013, 12:02 PM #2
- Nov 2012
- Worcester, MA
- 15
Anyone?
02-14-2013, 12:32 PM #3
Don't do installs anymore but back in the day yes and no. Should you? Yes. It's a very cut throat market in residential. 9 times out of 10 the low bid gets the work and I promise you his bid will not include duct sealing.
02-14-2013, 01:21 PM #4
Professional Member*
- Apr 2010
- NC Sandhills
- 191
Mastic all seams, better than most duct tape. There is also matic tape but it is cheaper to buy a bucket and brush but a bit messy it you dont give it time to dry before wrapping/hanging.
02-14-2013, 02:02 PM #5
- May 2004
- south louisiana
- 2,199
I use a combo of paint on mastic & mastic tape.
depends on what is being sealed & if it has to be wrapped
or how close duct take offs are on plenums.
having both on hand makes it simple.The cure of the part should not be attempted without the cure of the whole. ~Plato
02-14-2013, 10:11 PM #6
- Nov 2012
- Worcester, MA
- 15
Ok thanks for the responses. I personally prefer to duct seal it with paint on mastik because its the cheapest, but sometimes i use the foil tape, i would never use mastik tape its like $40 a roll. My boss insists we do it though i was just curious because i had the theory that its not a leak spot unless you undersize your ductwork. The way i see it is that the air wants to take the path of least resistance which is down the duct to the supply or return, why would it want to fight its way through a tiny crack if the duct isnt undersized.
02-14-2013, 10:23 PM #7
02-14-2013, 10:25 PM #8
- Dec 2003
- 2,051
some of us just care that much....
02-14-2013, 10:38 PM #9
where do you think the leakage goes...... outside.... don't think so...... done hundreds of houses zero problems ....and zero foil tape....lol
02-14-2013, 10:44 PM #10
- Dec 2003
- 2,051
Umm yes.... it leaks outside..... Thats why we seal the ducts....mastic is better than foil tape...lol
02-14-2013, 10:53 PM #11
02-14-2013, 10:57 PM #12
- Dec 2003
- 2,051
will do..... and its not just because of pride.....its cause its code....
02-14-2013, 11:06 PM #13
I hear ya not code hear on residential....commercial sometimes depends on the engineer..... i don't disagree with you just not common practice here...
