    Feb 2013
    All LED's light up
    Sometime during the day all the LEDS light up on the relay panel, the blower ramps up to 100%
    And stays there for ≈ 2-6 Minutes. What is this?
    I have all new Trane equipment: Installed 30-Oct-2012
    Tstat: TZONE950AC52ZA
    Control relay panel: BAY24VRPAC52DA
    Furnace: TUH2C100A9V5VAC
    Heat Pump: 4TWR5061E1000BA
    Coil: 4TXCC060BC3HCBA
    Humidifier: THUMD500APA00B
    Outdoor Temperature Sensor: BAYSEN01ATEMPA
    It is resetting all of the damper positions, and verifying that they all work.
    It's a feature, not an error.
    Feb 2013
    I don't have a zone panel or dampers. All the equipment that I have is listed.
    May 2008
    Central Fla.
    Where do you live and is the heat on? could be the humidifier coming on, not sure without more info.
    Feb 2013
    Kentucky
    Heat is on.
    The line set does not get hot and I don't believe that the gas comes on.
    When humidifier is on all six LED's light up.
    If humidifier is off only five light up.
