    Hanover, PA
    Hoshizaki KM-800MRE- evaporator tubing seperating from cube grid?
    I have a Hoshizaki ice machine that seems to be flooding the compressor. Can someone tell me how the evaporator tubing is attached to the stainless steel cube surface? It appears as though the "cube surface" pieces are just hanging there and not making positive contact with the evaporator tubing. Kind of looks like a curtain just hanging in front of the evap tubing on both sides and is not attached in any way. The right evaporator is worse than the left one.
    I'm pretty sure this is not the way it's supposed to be.
    Any insight would be appreciated!
    "Delay is preferable to error"- Thomas Jefferson
    Western New York
    Sorry to say the evap is shot. Likely the ice was backing up into evap due to scale, poor harvest or defective bin stat causing a massive ice block that presses against the evap.. No way to re-attach. Hoshi has a "proprietary" process to bond the stainless to the copper.
    Experience is what you have an hour after you need it.
    Hanover, PA
    What I figured
    Quote Originally Posted by baub View Post
    I was thinking it would be something like that.... oh well... the machine is almost 20 years old... time for a new one.
    Western New York
    The customer expects the piece to last forever, but the average life of an ice machine today is about 10 - 12 years. Hoshizaki ice machines seem to last a little, or much longer, depending on service and water quality.
    No point in replacing the evaporator on a 20 year old machine. The bin is probably OK. Yes? That saves some big bucks.
    Oct 2011
    Chicagoland Area
    Scrap the unit yourself if the owner doesn't want it. Copper/stainless pays pretty well.
    Pittsburgh
    scrap not worth fixing
