Results 1 to 7 of 7
    ICE-Con burner setup software
    Would it be possible to get a copy of that software (I know this thread is a couple years old...)
    I have some BMS work that we are doing with that unit and it has mentioned some of the parameters that I need to change/verify that I could only see through the software.
    Apparently the company is no longer in business, which makes it a challenge to support. Hopefully you still have the software available.
    Thanks!
    Ontario Canada
    The ICE-Con software is strictly for setting up the burner, and it's a bit flakey to boot. You'd not really want to 'link' to it with any BAS software unless you re-write everything. Too much trouble.
    I'll try to send you the software but because there are exe files, they may get trashed in the process of travelling to you.
    Searching for your email address next.
    D.
    Nov 2008
    Stoney Creek, Ontario
    any chance i could get a copy to.
    E-mail goes in your profile.
    i have just installed a new icecon 3( blue board) this replaces the old icecon II
    i have a m# HTDM-1500 MG1W
    the first board i install runs full heat, with 0-10vdc ddc signal removed, techg support said it was a bad board, installed new board and have same problem
    Ontario Canada
    8Snowman8,
    I'll send you a copy if you provide an email address, I couldn't find one.
    There's some mention of clipping a jumper on those IceCon boards to set operation to 0-10 or 4-20, maybe that might help.
    D.
    Nov 2008
    Please read the site rules.
    Your e-mail address belongs in your profile, and not in a post.
    Thank you.
