Results 1 to 13 of 13
    Aug 2012
    Antelope,Ca
    Cold morning Ignition problems
    I'm Still new to this site. I have been working in the industrie for 8 years. is this the right forum to ask for help?
    Ask a question. I'm certain many will have answers
    Sent from my SGH-T999 using Tapatalk 2
    Feb 2013
    corona ca
    HELP
    Quote Originally Posted by RDorr92788 View Post
    I just joined and think its the right place to share what we face out there ,what up with cold mornings ?
    Apr 2012
    winnipeg
    well ... could be......lol
    Oct 2011
    Chicagoland Area
    I don't know. What?
    Cold mornings = the drink I left in my truck the day before is nice and cold to sip on
    Aug 2012
    Antelope,Ca
    i have 2 antiqe carriers that wont spark if the oat is less than 40f. i have installed grounds from the pilot to the chasis. i have swapped ignition modules from another unit. you can light it with a torch. anything im missing?
    Oct 2011
    Chicagoland Area
    Move them inside a warm building and the problem should go away.
    Aug 2012
    Antelope,Ca
    LOL
    Southeastern Pa
    Some electronic boards are sensitive to low temps. The infamous JCI Blue Box and the Fenwal box used on Lennox and many York units are well known for low temp failures.
    Give us a model and serial number for the units in question.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Aug 2012
    Antelope,Ca
    Model # 48nlt060-500 serial #2790c94646
    Feb 2012
    Ottawa, Ontario Canada
    ignition Kit... When I encouter that I replace the ignition board, ignitor and flame sensor. I'd pull the burner tray out and clean the surface with grit paper. given that they are old they are probably very rusted, hard for anything to make spark of sense flame through the rust.
    I always sell this to the customer as a "kit", flame sensor and ignitors are cheap enough to just replace.
    Aug 2012
    Antelope,Ca
    thank you, i did tell my office to quote new ignition box and pilot assembly. so baybe i was on the right track. again thank you
